“ It is recommended to mount the PN 8202, PN 82023 and 8223 coils in an upright position. The High Vibration Coil, PN 8222, can be mounted in any position due to its epoxy potting compound.” Go ahead and mount them as shown in the photo Nux posted. They’ll run great until they don’t and they will live a much shorter life. They may even leak oil or burn up a little. |
Can you explain how there can be a 42hp difference between corrected and uncorrected readings please? Is your dyno at 4000 feet elevation? |
Probably to be taken with a grain of salt, like all dyno numbers. Not to say that's not a healthy motor, but 107hp/litre through SSI's and a muffler is a bit optimistic, especially given the RPM's at peak are pretty low. |
Those numbers look really high. Al from x-faktory did a 3.2 with a very similar setup (not dual plug and US compression but did ahve SSIs and Dansk 2 in / 1 out mufler, earlier in this thread) and a very generous dyno did not show uncorrected numbers as high as this.
I am next in line for one of Al's kits to go on my 3.2 with euro compression, SSIs and Dansk 2 in / 1 out. Quote:
Another follow-up set of questions. Did you do the below dyno in 4th gear? Would be interesting to see your graph on another dyno, do you have plans to try it on another one? Is this one known to be (very) gracious in its readings? It is so expensive to get 100 hp / liter out of our 3.0 / 3.2 engines...
Don't wanna be a debbie downer here but geese wiz what with 2300 for the throttle bodies another 4500 for the plug n play electronics ... Plus COP, Cranky Fire setup, machine shop head work, tear down for cam regrind or new install ... P/C's and Barrels ... etc -
I mean why not just go out and get a 3.6, get an adaptor/clutch kit and try a plug and play with that setup ... instant 280 hp stock and no dyno needed. Without cam and dual plug, high compression your ITB setup is still looking at around 5500 just for the ITB's and Brains alone and you only get a bump up of about 200 +/-10 hp rear wheel if truth be told IF your lucky and have a leaky sport muffler. Yeah @sbrown It sure is tough and silly E$pensive going this ITB route for such ridiculous and laughable returns for that kinda out lay. |
Link to piles of affordable 3.6s plsthx
http://forums.pelicanparts.com/uploa...1614341425.jpg
1984 full build for customer. Waiting on some small stuff and hopefully fire up this week |
Said it before, saying it again. Flywheel HP is USELESS. Unless the numbers were generated on an engine dyno and even then it isn't reality. I never understand people running cars on a chassis dyno and then extrapolating flywheel HP. I guess it gives a better number for feeding people's egos, but come on man...Tell us what is the uncorrected RWHP that the setup generated? What kind of dyno was it on also...Mustang dynos are easy to fudge because you have to input a bunch of variables and that give you lots of ways to inflate...DynoJets are the industry standards (IMO) and are generally pretty consistent from machine to machine.
@shamrock ... there are engines out there ... yes u have to go on a safari and hunt them down. Many avenues to approach this pathway. Mechanics, Insurance Co's, Yards, Engine builders etc. Affordable ? Yes subjective and yet I addressed some of the expenses involved with attempting to max out a 3.0 to the point u might as well just go on a 3.6 safari hunt. You are never gonna get anything with a 3.0-3.2 that even approaches a stock 3.6 without basically re-inventing the old platform. Yeah got to admit, you get a neat sound from the ITB's, credit card bragging rights and wine cork sniffing providence rights from your man cave but ya not gonna get 300 hp cause after all speed is like a line of coke. The more you have the more you want. - uncle dave
The "...not a requirement..." comment was meant to state that I don't think you need to be a professional engine builder to be taken seriously here. Regarding the coil leaking: My '75 arrived to me with a stock Bosch coil mounted with the output terminal pointed down. It was leaking from the other end of the coil (bottom of the coil but also the highest point as it was mounted upside down) where it contacted the AC coil mounted on the engine deck lid. Vibration wore through both the AC coil and the ignition coil case. My ignition coil was leaking oil, but not from where the can got crimped around the insulator. |
How did your car turn out?
The car is quieter at idle and cruise. The exhaust note is higher pitched. It roars when you add throttle/load and the valves open. The car has really come alive in the mid range and up. The part throttle response is incredible. I felt it most often when weaving between cars on the freeway, but tbh I haven't driven it that much because the rear bumper is still off. It goes to the body shop in two weeks for the rear bumper to be modified to accommodate the new center exit exhaust. As to intake sound, I think the GT3 plenum mutes that considerably. I do get some brilliant new intake notes when I come off throttle. If you want intake sound then suggest you go with trumpets. |
Interesting and thanks. Yes, I will be dropping my 3.2 targa off this Saturday for Al to install his Option 2 EFI ITB kit with rain hats.
Scott Quote:
http://forums.pelicanparts.com/uploa...1615324948.JPG[/QUOTE] |
Why? Did they not work well? Not sure if those ITG filters will fit Al's kit. Where did you get them?
Thanks, Scott Quote:
Guess your setup kinda goes like this. With all other things being the same If you want to get more power at higher rpm's then use shorter length yet wider intake runners ... If however you are wanting more power and response at overall lower rpm's then use longer intake runners that are more restrictive / narrower to create a more turbulence effect for increased airflow /velocity.
Previous versions...
Rain Shield http://forums.pelicanparts.com/uploa...1372124362.jpg Race Top http://forums.pelicanparts.com/uploa...1389560929.jpg Flat Top Filter on Flute http://forums.pelicanparts.com/uploa...1395525938.jpg Half Tea Ball Filter on Flute http://forums.pelicanparts.com/uploa...1399510787.jpg |
The ITG filters seem to make the most power while still providing enough filtering.
A few years ago we had a 3.5 on the dyno with PMO ITBs. We had the chance to dyno 2 different set ups. I don't have the sheets, like I said, it was a few years ago. But, we tested the often thought of restrictive "rain hat" set up vs open velocity stacks with no filter. The thought of "worst" vs the "best" in terms of power. We saw no measurable difference on that particular motor. Yes, one sample size done back to back within an hour of each run. We did post something regarding that tidbit at the time. For years there was lots of hyperbole about what filter flowed best and what cost you power. Lots of "white paper" type thinking. So we had the chance to do a ONE time test with ONE motor combo, so we did.
A filter on an ITB motor hurting performance means everything else in the complete engine system is dialed to 110% and drawing more air than the filter can deliver without restriction. I wish we still had the dyno plots. Maybe we will going forward with engines that see the dyno... Anyways, food for thought. |
What’s the consensus of shaftless (AT Power) versus others with a shaft/butterfly?
You mean these:
http://forums.pelicanparts.com/uploa...1615746245.jpg They work really well. What is your application? |
Street stock Euro 3.2. Want reliability but miss the sound of the Weber’s
They won't pass the visual inspection CA smog...is that an issue?
That's cool.....
I would contact William Knight (knightrace at mac.com). He can tell you what ITB size (I assume 42mm) and intake port size would work best and get your a quote. |
Do you have an EFI ITB kit from x-faktory / Al? How well do the ITG foam filters hold up to keeping rain out of the intakes? Does the foam get saturated in a heavy rain?
Hi Scott,
My kit are PMO EFI. As for the ITG foam filter, it will be the first time I will run them on the road. As for water in the rain... I drove with the top down in a piss down rain at 60 mph and thanks to physic, I did not get a drop in the cab so I doubt anything happened in the engine bay. JJ Quote:
Dean |
And so it begins...
http://forums.pelicanparts.com/uploa...1615910601.jpg http://forums.pelicanparts.com/uploa...1615910615.jpg FYI, I will be selling the following from this upgrade: - basically everything you see removed between the two pictures (the full euro factory intake system with the aftermarket filter and tube) - DME, wiring harness and Steve Wong euro chip Send me an email if you are interested to purchase the above, Scott |
Scott,
I noticed this WTB last night.... http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1088446-wtb-3-2-3-6-intake.html regards, al |
| All times are GMT -8. The time now is 01:18 PM. |
