Feel bad for Scott. Can easily come to believe that ITBs and new engine management will unlock a world of performance. At some level, it’s wishful thinking to avoid the multiplicative dollars required on the ground up internal work to truly move the needle. Good reminder but painful for Scott so I feel for him. That’s not any way suggesting some fault by Al - expectation is always resentment under construction (how much resentment depends on how much expectation!)
If there is a takeaway for me, it’s that a chipped motronic system is pretty adequate. |
based on the dyno graphs and how my newly installed itb's affected my own car I would guess the car at discussion drives nicely and better than before. Imrovements in dyno graphs are not insignificant and problem appears to be unrealistic expectations.
80SC (ex California) |
scumbag
There's been a lot of discussion about power increases (expected vs realized) and about drivability.
But I just got back from a 60 car rallye in the mountains of WV and I can assure you all of the ITB/EFI guys got markedly better fuel economy than the CIS guys. Doesn't sound that important until you get to the bottom of the mountain on Monday morning to tank up and head home and find there is no gas at the station. I wasn't worried as I knew my 1/2 tank would easily get me to the next station. My friend next to me in a CIS car was worried. (we did both make it to the next fuel station)
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
Nick here too from Ruchlos. My car on ITBs was sipping fuel too - thought i was crazy! Glad to see your car here. WV again soon.
nick@lauernteile.com Founder LAUERN TEILE. Retrofuturistic parts for the Porsche 911 enthusiast. |
scumbag
The 911 did get down to ~18mpg on one of my Ruchlos tanks of fuel. Probably when I got to idle up and down 11 miles of gravel mountain road...
DIY wrencher
Very cool! Since the BMW engine is an inline six, did you use 2 throttle bodies and cut off the 3 TBs on the end, to have the motors to control both banks on the Porsche? How did you adapt them to the head? I've seen another drive/ride by wire ITB kit on Ebay from T.O.Performance , it uses some Triumph motorcycle E-TBs although I am not sure which.
That's a clean looking setup.
On a sidenote, has anyone ever tried to adapt BMW S54 M3 throttle bodies to a flat six? |
DIY wrencher
AFAIK , he is using Suzuki 1000cc throttle bodies , and controls them with the bmw electronic throttle motor .
Happy holidays
![]() ![]() Sent from my iPhone using Tapatalk |
Following this. Interesting!!
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Post your ITB Setup
I have a question for the experts here. I got a great deal on a 46mm PMO ITB setup complete with engine management. I have a 2.7 RS spec engine with S spec cams. Are these 46mm PMO ITBs too big or can that be tuned in the ecu management to work? Should I be looking at reducing the 46mm ITBs?
Also Happy Holidays! |
The 2.7RS is a great build and lots of fun....they make decent power and spool up nicely. I typically use 40mm ITBs for that engine configuration....and they work very well.
I expect that you could install the 46s and use the ECU to tune them up to work with your 2.7....but you would likely sacrifice smooth tip-in and low RPM torque/throttle response.....but come alive in the upper RPMs.... That, combined with the S-cams might make it ok for a track with long straights, but no fun around town or as a canyon carver....so basically sacrificing what makes that configuration so much fun. The 46mm PMOs are really nice ITBs, but I wouldn't apply them to the 2.7RS and would save them for a hot 3.2 or a 3.6. regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
ITBs
Many years ago I adapted the Triumph Speed Triples to work with 911 engines.....it was a decent, affordable setup, great fun, worked pretty damn good and quite a few were installed...all over.... etc...
![]() ![]() now I've moved on to these....... very nice! ![]() regards, al
I was hoping you would chime in Al. Thanks for the feedback and information. The car isn’t going to be a track car but rather mainly street and canyon car.
I may need to start looking for replacement or someone looking to trade my 46mm ITBs for their 40s. |
I have a 3.2SS (or larger) build coming up. I may be interested in trading 40s for you 46s. PM me and we can discuss.
regards, al
Who makes those velocity stacks?
