Following
Sent from my iPhone using Tapatalk |
I paid $1000 (10 hours at $100) for Al to tune my car. It was delivered twice with a bad / incomplete tune. After getting the tune corrected by a dyno shop with a very good tech it appears the car was delivered with a malfunctioning temp sensor for the Megasquirt ECU. Does anyone know where this sensor would be for those that have Al's kits installed? Otherwise, I will have the tuning tech trace the wiring from the Megasquirt to the block. Hopefully it is an easy sensor replacement as it is needed for cold starts yet it was causing the tune to go randomly rich at warm operating temps. Both my mechanic and the lead tech at the dyno shop cannot believe the car was delivered with these issues.
Scott Quote:
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs |
What temp sensor are you using? I have my car at a shop getting tuned now. I had an AEM oil temp sensor in the left cam cover as that’s what I’ve seen many others do around here and my car, ‘79 SC, did not come with a CHT. One of the first things that the shop pointed out was the inconsistent reading that the oil temp sensor and its location may give. From what they told me, it sounded like the sensor wasn’t seeing accurate temps and holding the car in warm up for much longer than needed. I had them instal a CHT on one of the heads fins per their recommendation. Might just be a preference of theirs with tuning but might make sense for a lot of set ups
Josh @joshgrowth |
Also, have you talked with Al about the issue? In all of my exchanges with him he has been a 110% stand up guy. That matches everything else I’ve seen on the forums until this post
Josh @joshgrowth |
Yes I have. Al is refusing to do any more work on my car after I identified and notified him of multiple issues after the second delivery of my car. I have never experienced anything like this before. I just want my car to start and run like it did before the upgrade.
Scott
kinda slow
Regarding your temp sensors, you should have an intake air temp (IAT) sensor and a cylinder head temp (CHT) sensor. The intake temp sensor is likely a GM part and threaded into one of the ITBs. The CHT (your likely culprit) is possibly a ring terminal thermistor that is using one of the upper valve cover studs or one of the oil lines to get a temp. Both are easy and cheap fixes if faulty. Sorry to hear your experience regarding Al, he's always been helpful to me without me spending a dime with him.
1983 911 SC Coupe |
I don’t typically have to defend myself, my systems or my work and doing so on a forum is usually an exercise in finger-pointing………but I will keep this as short as possible.
It took me two tries, but eventually I provided a system/tune that met worked very well and….seemed to meet Scott’s requirements. The 1st tune was running a bit too rich and seemed to rev limit at 5000 RPM in 1st…….too rich during cruise, etc. I suspect that I may have inadvertently loaded an earlier tune....as i had addressed those issues........ Scott provided me with a list of about 10 items that needed to be addressed..Most of the items were tune related and one item was related to a paint chip adjacent to the engine lid. I spent a lot of time making sure that I addressed the points on Scott’s list. I followed up with a leak-down test that showed the engine was healthy and took it out for a final run and video…..ran great. I often take these videos to have a record of the condition of the car/tune, prior to shipping Here’s a link to the video……. Video is kind of long and boring…but the 911 ran great and the logs showed that the AFRs were decent too. https://www.youtube.com/watch?v=CIXcacSzjDM&t=7s So, that was a wrap and Scott emailed me on 05/20: Hi Al, "Car made it back safely and took it for a drive. It is so much better than the first time I picked it up. Hand throttle worked as expected and was no problem. Idle was great an pulled hard up to redline without any breakup. I could not get on it too much as it was rush hour traffic in semi-back roads. I think I may have lost a little throttle response / torque in 2.5k RPM - 3.5 RPM takeoffs, but I am not totally sure. Might be interesting to do a dyno tuning session. Hopefully that can be done in a few hours with our carb rebuilders in Kirkland (Carb Connection). Speaking of which, did you make a backup copy of my current file? Thanks again, it was fun, interesting and exciting to drive..." Scott My response: Thu 5/20/2021 6:42 PM Scott, Glad that you are happy with it....it definitely took some time. Torque doesn't come on until 3500 +....but you'll definitely need the dyno to refine that area. I did remember to make a copy for you.. Since that happy day Scott has contacted me regarding the rock chip……basically implying that I dropped and dragged something heavy over his fender causing scratches and it needed to be repainted/blended…..……… I guaranty that this never happened. However the chip may have. I told Scott to get an estimate and I’d consider helping with that…….but in the back of my mind, an alarm bell went off as a simple chip escalated into much more. In the pic below, the arrow is pointing to the chip……. Next , a week or two later, Scott emailed me that his brake lights and backup lights weren’t working. My reply to this was that the EFI system just replaced the engine/control harness and did not get into the chassis or front/rear lighting harness(s) at all. Also, in general the wiring in this car is a mess, with clipped off wires, butt splices and even household electrical wire-nuts used on some connections. Pretty much par for the course for an early car that has been forward dated and has been implanted with a 3.2 back in the day. I don’t believe that this issue was related to the EFI install ….and don’t accept responsibility for the general lighting/wiring problems. …..More alarm bells were going off in my head……..and I told Scott that I would not work on it. If there is a failed temp sensor on the system, I will provide a new one…….anyone that has dealt with me knows that………. My take on this is……Scott is basically just not satisfied with the Dyno run …. ……….. The dyno tuner did a good job…..(he is supposed to find ways to improve the tune and he did) … ….…..and based on the dyno run data presented, it is performing better than the previous chipped configuration, pretty much throughout the range …..just not to the extent others have experienced. So it may be missing the bragging rights element. I’ve never been to a dyno…I tune on the road, but often recommend that you go to a dyno to refine the tune and get the last percent. I never guaranty HP and TQ improvements, because there are other things involved besides the EFI kit……but I do refer to my customers dyno runs for reference as that is unbiased, 3rd party results. However, your results may vary………. Anyway, the internet is a particularly poor way to communicate, but a particularly good way to injure someone’s reputation. Regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
I can only say my interaction with Al has been professional. I think that the one complaining should take off the stuff he doesn't care to understand and go back to whatever engine setup he was running before. Furthermore, I think the expectation of a forward date basket case can be anything but subpar. I am planning to install one of Al's kits on my 2.7 and he offered his tune service which I respectfully declined because the engine was unknown and I needed to ensure it was up to par before I would even think about sending it to him.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Hi Al,
I don't want this to escalate. Overall, I am happy with my current dyno tune of the system. This Option 2 project resulted in a very slight upgrade in performance for torque and hp and 3 dyno runs prove that. I did expect more. With that said, the documented problems with my car after the delivery have nothing to do with my feelings about the upgrade. Let me address them specifically: - I just inspected the yellow wire for the temp sensor and the fan shroud bolt was loose after you helped me out in your email reply. In fact, 4 others were loose also. Not sure how this happened but no one has touched a bolt in the engine bay since the car was delivered. I tightened it and the temp sensor is reading correctly in TS. Thank you. - My mechanic addressed the brake and reverse lights last week. After investigation, he found 50% of the fuse box up front did not have power. He ran a jumper from the one side of the box to another and I have reverse and brake lights now. Obviously this was from the upgrade work as my fuse box and lights were working correctly before. - The paint chip was not there when I dropped the car off for the install and it does not show in a video I took of the car running for the purpose of selling the factory intake system just before I dropped the car off. As for the closely located scratches, I do not remember them being there. Scott Quote:
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs Last edited by sbrown.nw; 06-07-2021 at 07:56 AM.. |
Al is as good as they get for keeping his clients informed and involved, but if you want turn key mods then you're going to have to open your wallet a lot wider into Singer territory. |
Wait so instead of fixing your fuse box the correct way you let your "mechanic" run an extra wire????
ITB`s as it is hardly will give anything, probs just a bit. Which is fair enough. |
THIS! Well said.
76 911S Land Rover 110 Defender |
I'm Australian so unfamiliar with the term.
Racer
Ever heard the phrase "correlation does not imply causation"?
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Gary R. |
Only at the wheel numbers matter, so my expectations of 210+ whp, 200+ wheel torque were not met.
This is a temporary fix. I've learned a lot about this car and do not know it's entire history. When I bought it in 2007 the PPI did not say anything about bad or questionable wiring. I am trying to make it right / better incrementally each year I own it.
Scott
Grappler
Al is one of the good guys. He once sent me a part I needed (on his dime) without even charging me shipping. He's as stand up as they come. No reason to bring this dispute onto a public forum IMO.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
