LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Cars Ruined My Life
impactbumper's Avatar
Impressive Fly911
Old 08-31-2016, 09:03 AM
al lkosmal's Avatar
[QUOTE=sp_cs;9262236]No offence intended as i know little about not very much, but is that dyno plot accurate? That's showing 30-40 bhp/torque gains with your upgrade package? Care to detail the changes?
sp_cs....no worries.........I had posted a composite to make it easier to see before/after, but here are the actual dyno runs, and description as originally posted by the Dzug guys.....
"""Thats a whopping 24hp and 30(!)lb/ft gain over the stock CIS for an identical motor, SSIs and megaphones.
The car has been transformed, pulls crisply and SOUNDS amazing with the ITBs.
There are still gains to be had with tweaking the timing, and we could probably get more out of her still if we had coil packs, but not bad """
here's a link to the original post
D-Zug Tours RSR dyno
and dyno pull vid
https://www.youtube.com/watch?v=QdXp67tdbbE
https://www.youtube.com/watch?v=xaj0FyEmc68
https://www.youtube.com/watch?v=hIehm1WuxPI&feature=youtu.be
RGruppe #669
http://www.x-faktory.com/
Old 08-31-2016, 09:44 AM
CBRacerX's Avatar
Incredibly helpful, thank you!
I've got a fresh stock SC (small port) build that I'm getting running on carbs, but I think will be ITB in the future. Tried it once before in the 90's with a TEC3 ECU and TWM but never got it running well.
Originally Posted by 3literpwr View Post
I started buying all the bits and 3D modeled my own system, but opted to go carbs. In the end, I felt that the cost was too close to carbs and that my home brew EFI will have no value to others in the end.
Home-brew ITB setup
Triumph 900 ITB's $50
Tubing 100
Flanges 50
Bungs 50
boots 50
venturi 200
ECU 1375
Injectors 250
Fuel pump 150
Regulator 150
Hardware / lines 100
Welding / fab 250
Filter assys 130
Eids 200
Tuning time 0
Crank trigger 300
Throttle linkage 100
Wide band o2 200
Total $3,705
Jenvey ITB with PE-LTD ECU
ITB 3200
Ford EIDS 125
Injectors 200
TPS 100
ECU 1375
Wideband 300
Wires 300
Harness 143
Crank Trigger 300
Total $6,043
Vems with Borla
TWM / Borla ITB 2300
Vems 1535.91
COP 460
TPS 100
Crank trigger 220
Pickup sensor 50
Injectors 250
Total $4,915
PMO / Dist
Carbs 4100
Dist 1300
wires 300
6-AL2 CDI ignition 500
Coils 90
Total est $6,290
Chris
https://dergarage.com
‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900
Old 08-31-2016, 11:28 AM
Looks like the juice was worth the squeeze. Could probably go even better with a bit more cam. Regardless, I like it.
Currently waiting for the MFI machine work to be completed for the 2.8 I'm building.....the good guys are always backed up.
No physical quantity completely explains its own existence
Old 08-31-2016, 11:37 AM
Turbonut
Raceboy's Avatar
Most ECU's suck at getting ITB's to run perfectly on the street. Because a) they have only speed density tuning strategy available (which is useless with ITB's), b) they have only Alpha-N mode available (also useless on anything but a race car).
Key to getting ITB engine running perfectly is to have at least MAP compensation table+MAT compensation table on top of Alpha-N or the best method is to have MAP/Alpha-N hybrid load.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 08-31-2016, 12:04 PM
I would rather be driving
jpnovak's Avatar
hybrid SD/AN modes exist in many software systems. However, to get them to work requires some knowledge and experimentation to overcome the issues changing from one mode to another smoothly.
Also, It is not so difficult you get ITBs to run well with SD algorithms provided you understand the scaling required to match the non-linear MAP signal versus load. I do this often with very nice results.
As they say... "give the engine what it wants".
There are many solutions to the ECU and tuning component of these installations just as there are hardware and intake solutions. One size does not fit all.
Old 08-31-2016, 01:37 PM
Using a Resonance Plenum over ITB's results in a 25-45 lbs-ft torque boost from 2K to about 5500 RPM, all things being equal.
The effect is quite noticeable and works on all 911 engines.
Naturally, the plenum must be sized (matched) to the displacement.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-31-2016, 01:47 PM
Cars Ruined My Life
what plenum is the choice for 3.2?
Old 08-31-2016, 04:27 PM
24-45lbs... thats a lot!
has anyone done back to back test with the a 964 plastic mani ITB 3.2 dyno to see were the gains are?
i would assume its helps a lot for low rpm running issues with the ITBs.
i have a 3.2 twin plug, 964 cams now and plastic 964 mani sitting on the self.
Old 08-31-2016, 04:55 PM
Cars Ruined My Life
What engine management are you going to use with that 964 manifold. And it is not a direct fit. Are you going to use it with itbs?
Old 08-31-2016, 05:02 PM
Turbonut
Raceboy's Avatar
Agree, though tuning by pure SD with the effective available MAP range of 70-100 kpa is not going to make a perfectly running car. And if you have wilder cams then range will be even less. Problem is that you will have many overlapping VE table areas, even though you may divide VE table MAP cells in 2-3 digit inceremtns at higher rpms. Transient response at low rpms/loads (= city driving) will be compromised.
BTW, I always give engine what it wants
Old 08-31-2016, 09:14 PM
hawaiipcar's Avatar
Send a message via Yahoo to hawaiipcar
Very cool information from all.
HAWAIIPCAR
75 911 S
Old 08-31-2016, 10:52 PM
Depends on cams and compression ratio,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-31-2016, 11:47 PM
sp_cs's Avatar
Originally Posted by metalracer View Post
Here's my twist on an ITB setup from TurboKraft, powered by Rasant Products AEM Infinity ECU kit:
Liking the plenum - bespoke or off a shelf?
I've bought 993 intake halves as a starting point. Sending to William Knight for his t-piece filter arrangement to be made up.
Shirish
1987 Carrera, Granite Green
Old 09-01-2016, 12:13 AM
Chain fence eating turbo
MegaSquirt has an "ITB mode" that blends Alpha-N and Speed Density.
I'm going to try that 1st and experiment. If it doesn't work out, I'll try jpnovaks tried and true method.
Old 09-01-2016, 04:12 AM
I was thinking of doing the mod in increments since the motor runs well. I would first try adapt the plastic manifold with custom short intake blocks in which I recall a few people sell already. You can trigger the resonance with a aftermarket adjustable shift light. I'm not sure you can get away by just re-chip the motronic?
Next phase would be a stand alone followed by ITB's. No know itb's aren't worth the $ if you aren't spinning above towards 8k but the look and sound fantastic.
Old 09-01-2016, 08:57 AM
sp_cs's Avatar
No know itb's aren't worth the $ if you aren't spinning above towards 8k.
Al ikosmals dyno plot contradicts that somewhat?
Shirish
Old 09-01-2016, 09:14 AM
no i dont thinks so but thats just my opinion. i dont know much about that motor other that is a 3.2SS which should spin more freely than a 3.2. the dyno graphs indicated thats is a nice warmed up street motor peaking around 6100. i think Al builds nice motor with creativity given the realistic budget of normal folks like us. if he had an open wallet then all this would be easy.
basically once you replace the standard CIS( toilet plunger) with EFI you a eliminate significant restriction on the intake track. thats were most of the gains are along with more precise fuel metering. Be it itb carbs, efi with log manifold or itb efi, the peak gains will be similar its just that drivablity, torque curve and character may differ
itb tuning at low engine speeds are more difficult compared to a log type tuned manifold especially with hot cams which is why you kinda wanted itbs in the first place right? with these late type variable manifolds (that steve have posted) adapted to the top of itbs, you can improve running issues at low speed and thickin up low end torque curve.
Old 09-01-2016, 11:37 AM
Turbonut
Raceboy's Avatar
Having manifold on top of ITB's does not change the tricky nature of tuning the ITB's at all.
Old 09-01-2016, 12:43 PM
Ferrino's Avatar
It does open up the possibility of using a MAF sensor, though.
Old 09-01-2016, 02:08 PM
