Fast Flashing indicators 73 T
Hi guys just to run something past your brains , the indicatos are working on all four corners but flash faster than they should . On the gauge the left hand arrow flashers the same speed as the turn signals but the right side the arrow flashes the same speed as the right turn signals but at the same time the left flashes too. When i use the hazzard lights they all flash at the correct speed so its not the bulbs right??? i may change all of them just to be sure .... Your thoughts pelicans.......................................... ............
jonny
Old 08-28-2016, 01:48 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Are the bulbs incandescent or LED?
'85 Carrera Targa
PCA/POC
Old 08-28-2016, 03:31 PM
incandescent
Old 08-28-2016, 11:03 PM
DRACO A5OG's Avatar
hmmm, and all light work, maybe the flasher relay may be going out?
'85 Carrera Targa
PCA/POC
Old 08-28-2016, 11:25 PM
Send a message via Skype™ to Porboynz
I am not sure about the US version but the Euro version has side marker indicators as well as the main bulbs. I resolved similar problems by changing from cheapo Narva bulbs to not so cheap Hella bulbs and making sure the side indicator mini bulbs were functional. Seems the flasher and the gauge indicator lights are dependant on the correct current load, well it worked for me.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 08-28-2016, 11:29 PM
prschmn's Avatar
If they were working correctly with the bulbs you have but arent now it is
likely the flasher relay
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 08-29-2016, 04:14 AM
I will give the relay a shot and report back , where would I find the turn signal relay ?
Cheers Jonny
Old 08-29-2016, 10:30 AM
DRACO A5OG's Avatar
Behind the gauges and you can also see it thru the frunk
'85 Carrera Targa
PCA/POC
Old 08-29-2016, 10:46 AM
Hi guys so an update so far the relay clicks fast when the turn signal indicator is either on left or right . However the same relay clicks as it should when on hazards lights . ....??
Anyone
Old 09-01-2016, 10:53 AM
wayner's Avatar
Burned out bulb or bad ground
SOLD - 914 wide body hot rod
Old 09-01-2016, 10:57 AM
So all the bulbs work but I may change them anyway I have cleaned the ground that are on my rear bumper quarter bolts I haven't done the front yet ?
Old 09-01-2016, 11:04 AM
If cleaning all the earth points does not solve it then try adding additional load to either side with a clip on test lamp. You can make one up with a 10W 12V bulb and clip leads. If that slows the flashing then you know your problem. (Its easy to clip on at the fuse panel)
Old 09-05-2016, 10:45 PM
