New-ish 911SC Targa Owner
pampadori's Avatar
removing timing chain ramps
I'm considering powdercoating some engine items and would like to include the timing chain covers. How are those chain ramps removed? i applied some pressure but they didn't seem to want to come off.
Also, i've read there are black and brown ones. Can someone give me the brief on which is preferred and why?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 10-05-2016, 09:01 AM
The ramps are on the housings bolted to the case, are these housing what you a referring to?
You should be able to simply pop them off with a large flat blade, they have a spring clip holding them on. Since you are removing them, I would not worry about damaging the ramps as you should replace them.
The brown ramp goes on the lower passenger side (one that is in the case half) and is either shorter or longer (don't remember which) in order to differentiate it from the identical black ramps.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 10-05-2016, 09:15 AM
pampadori's Avatar
that's correct, the two boxes that bolt to the case. Its been a while since i took things apart and couldn't recall which the ramps were on. So both the left and right sides just snap on and off? i'll try to grab a larger flat screwdriver and put more back into it. and plan to replace them both with new items even though these are pretty new-ish still (tensioner update was done in the last few years from the looks of things).
Old 10-05-2016, 11:18 AM
Peter Zimmermann's Avatar
You really should have a manual for this job. I use an old fashioned brake spoon (drum brake shoe adjuster tool) to remove the single ones inside the chain housing. The other four ramps are located inside the engine case, and require bolt removal to remove the ramps. You will need new seal washers for the four bolts on each side (8 total). Pay attention to the ramps, they have a long end and a short end. The long ends point toward the closest chain sprocket, in other words, the long ends of the 4 ramps in the engine case point toward the middle of the engine case. The long ends of the two outer ramps point toward the chain sprocket on each camshaft.
Keep the Shiny Side UP!
Pete Z.
Old 10-05-2016, 03:31 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Leave the box and ramps alone just do the covers. Removing the ramps will most likely break them and you will need to replace it.
'85 Carrera Targa
PCA/POC
Old 10-05-2016, 03:40 PM
Kraftwerk's Avatar
If you paint the timing chain cover you need to use a two part etching-primer since it is aluminum, right? Otherwise it may 'reject ' the paint in few years.
I guess those ramps are a 'wear-item' ( plastic ! ) I should check mine.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 10-05-2016, 04:27 PM
Bling, bling. Don't do it.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-06-2016, 06:27 PM
