Another TDC Distributor removal question
Hi Guys,
So I have removed my fan and shroud and sent them off, I now need to remove my distributor. I have lined up the rotor button to be in line with the notch on the dizzy casting. As I can't line up my flywheel pully notch to the shroud's TDC mark, is it enough to just have the button lined up? Am I good to pull the distributor? I have photographed it and the notch on the pulley is at the top as best as I can tell. Thanks!!
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
Mighty Meatlocker Turbo
Spence, that will work just fine.
A couple of things worth mentioning - it will take a fair amount of force to pull the distributor out of the hole ( ![]() ![]() PS - the fan housing's TDC mark is aligned with the case seam. Last edited by Rawknees'Turbo; 10-18-2016 at 10:19 PM.. |
Member 911 Anonymous
+1
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks so much guys!
The Dude abides...
Spence,
Don't sweat it too much. Like the others have stated, if you're attending to the marks, you'll be just fine. I was really sweating it when I reassembled my 3.2 and everything turned out just fine. Good luck!
Steve '03 Carrera 4S |
note how the rotor will turn when you remove the dsit. you will have to offset the rotor when installing so as it goes in the rotor will turn to line back up.
VERY important: put a clean rag in the dist hole!!!
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Thanks so much for the help guys, really appreciate it!
Thread Tools | |
Rate This Thread | |
