spence88mph's Avatar
Another TDC Distributor removal question
Hi Guys,
So I have removed my fan and shroud and sent them off, I now need to remove my distributor. I have lined up the rotor button to be in line with the notch on the dizzy casting. As I can't line up my flywheel pully notch to the shroud's TDC mark, is it enough to just have the button lined up? Am I good to pull the distributor? I have photographed it and the notch on the pulley is at the top as best as I can tell.
Thanks!!
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 10-18-2016, 09:17 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Spence, that will work just fine.
A couple of things worth mentioning - it will take a fair amount of force to pull the distributor out of the hole (), since the oil seal on the shaft fits very snugly in the bore (another , right!), and if you put some precise index marks on the body of the distributor and the case, you will surprise yourself at how close, or perfect, your advanced timing is when you re-assemble and check with a timing light (assuming it's good prior to removal).
PS - the fan housing's TDC mark is aligned with the case seam.
Old 10-18-2016, 10:10 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1
'85 Carrera Targa
PCA/POC
Old 10-18-2016, 10:18 PM
Thanks so much guys!
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 10-18-2016, 10:56 PM
The Dude abides...
bigel's Avatar
Spence,
Don't sweat it too much. Like the others have stated, if you're attending to the marks, you'll be just fine.
I was really sweating it when I reassembled my 3.2 and everything turned out just fine.
Good luck!
'03 Carrera 4S
Old 10-19-2016, 01:39 AM
T77911S's Avatar
note how the rotor will turn when you remove the dsit. you will have to offset the rotor when installing so as it goes in the rotor will turn to line back up.
VERY important: put a clean rag in the dist hole!!!
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-19-2016, 04:14 AM
Bill Verburg's Avatar
Originally Posted by spence88mph View Post
Hi Guys,
Thanks!!
even if you lose all the orientation it's not a big deal to return it to TDC #1 compression
Bill Verburg
Old 10-19-2016, 04:49 AM
Thanks so much for the help guys, really appreciate it!
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 10-19-2016, 03:58 PM
