NeedSpace's Avatar
Bad engine noise in 2.7 Middie - Detonation?
{FOLLOWUP NOTE-Noise was NOT detonation but a rocker arm that had come loose, skip ahead to see}
OK Pelican braintrust, my 2.7 has taken a bad turn. I was driving it at about 65 and suddenly it started making a very concerning noise. Keep in mind, the engine has been running wonderfully for a few years with no big issues. I pulled over and had it towed home. There was a bad oil leak (not a drip like I usually get but a bit of a stream) that was uncharacteristic of my girl. I had started posting this in my long thread but thought it might me more interesting to get this in a single thread.
1976 911S – from garage find to on the road
Here is the noise it was making. This is the noise before taking anything off the car. At first I thought it was a banging but now I feel pretty confident it is an untimely detonation (or hoping...) {FOLLOWUP-NO, rocker arm NOT detonation}
Since then, I was able to take off my heat exchangers with little fanfare and had a better look. This is what cylinder 4 looks like from underneath.
This is what it looks like when running from underneath. Interested in all ideas...
Notice cylinder 4 doesn't appear to be firing and there is an oil leak very close to that cylinder.
Old 11-27-2016, 03:51 PM
emac's Avatar
That sounds like metal on metal. Bad rod? It doesn't sound good sorry to say
Ernie
Old 11-27-2016, 04:45 PM
Finhead
As mentioned in the other thread, check the rocker shafts/rockers on that bank.
2cam
Old 11-27-2016, 05:02 PM
Are both valves opening? Does it perhaps have a broken exhaust rocker?
I've heard a bunch of sick 911's over the past 37 years but that's a new one on me
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 11-27-2016, 05:04 PM
NeedSpace,
That is not detonation.
Sounds like timing may have skipped - as in cam timing. The cam timing chain may have skipped a tooth. Pull the timing chain covers and see if the chain tensioner on one side has collapsed. Or you could check cam timing on #1 and #4 - it only takes a few minutes on these old cars with nothing in the way.
While the valve covers are off, check for broken rockers.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 11-27-2016, 05:07 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap, open the valve covers and look at the rocker/shaft.
You Must CHECK the Rocker Shaft Bolts when you DIY Valve Adjust!
Here is the fix:
964 Cams Swap Journey
'85 Carrera Targa
PCA/POC
Old 11-27-2016, 05:10 PM
NeedSpace's Avatar
Holy crap that sounds EXACTLY the same. Once my kid goes to bed, I am headed out to the car. I'll bet that is it. Hopefully, it hasn't done too much damage.
Old 11-27-2016, 05:40 PM
DRACO A5OG's Avatar
I bet it is the lower rocker shaft.
Don't worry, if rocker did not snap, it will just be sitting in the valve cover. Don't worry about oil loss, some will drip out but not much, just be prepared.
'85 Carrera Targa
PCA/POC
Old 11-27-2016, 06:18 PM
Flowing out fluid......
Needspace,
What was that fluid coming out from the engine after the engine stopped running? Gasoline? Do you still have the fuel injection system?
Tony
Old 11-27-2016, 06:24 PM
NeedSpace's Avatar
You guys are the best. I took off the valve covers and sure enough, look what I found!
This is exactly what I DRACO reported on in this link, thanks!
Thanks for the reference, this was perfect.
A quick inspection of the rocker arm and the shaft looks like there is no damage. But shouldn't the shaft have 2 gaskets that this is not showing? If so, it could explain a lot of the extra oil I get on my covers that I haven't been able to resolve.
Old 11-27-2016, 07:15 PM
DRACO A5OG's Avatar
No Brother, stock has no seals, the RSR seals is an update/upgrade.
Take a closer look in day light and inspect that Cam Lobe carefully by hand cranking her. Please disconnect the battery
While you are there check all the shafts for possible movement/looseness per my thread above
'85 Carrera Targa
PCA/POC
Old 11-27-2016, 08:34 PM
NeedSpace's Avatar
Originally Posted by boyt911sc View Post
Needspace,
Tony
Tony,
I am trying to keep my car fairly stock so still using the bosch mechanical fuel injection. That liquid is a whole lot of oil.
Old 11-27-2016, 09:39 PM
NeedSpace's Avatar
DRACO, ah, ok, I'll order the RSR. I am going to check each one and put the seals in while I am in there. I have read through your posting twice already. I don't think it'll be that last time too!
Old 11-27-2016, 09:40 PM
ROW '78 911 Targa
timmy2's Avatar
It happened to me too 4 years ago....
Finally, back in the game!
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-27-2016, 10:03 PM
Constant Injection System.........
Originally Posted by NeedSpace View Post
Tony,
Oil coming from where? BTW, you have a CIS and not the real MFI (mechanical fuel injection) system. CIS is easier to maintain than a MFI. You need to torque the rocker shaft bolts @ 13 ft.lb (156 in.lb) to keep them in place.
Tony
Old 11-28-2016, 07:21 AM
scarceller's Avatar
Few points on detonation:
Detonation at idle and very light loads is really not possible, you don't have enough cylinder pressures during combustion at these light loads. It's very unlikely to cause detonation at idle no matter how lean you make mixture. Even over advancing ignition won't cause detonation either at idle.
These motors are really only detonation prone at loads above 50% to WOT.
Glad you found the problem, rocker arm shaft that walked out.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 11-28-2016, 08:17 AM
RETIRED
Joe Bob's Avatar
An RE agent that knows how to wrench, priceless. Hope it goes back together and no problems.
Good luck.
2012 ML350 3.0 Turbo Diesel
Old 11-28-2016, 09:03 AM
NeedSpace's Avatar
Good luck.
RE Agent? Actually I am a psychologist...
Old 11-28-2016, 10:01 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
this looks like a happy ending!!
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 11-28-2016, 01:50 PM
DRACO A5OG's Avatar
LOL, he is writing about me's :P. I am a better Agent than Mechanic :-)
'85 Carrera Targa
PCA/POC
Old 11-28-2016, 02:47 PM
