Bad engine noise in 2.7 Middie - Detonation?
{FOLLOWUP NOTE-Noise was NOT detonation but a rocker arm that had come loose, skip ahead to see}
OK Pelican braintrust, my 2.7 has taken a bad turn. I was driving it at about 65 and suddenly it started making a very concerning noise. Keep in mind, the engine has been running wonderfully for a few years with no big issues. I pulled over and had it towed home. There was a bad oil leak (not a drip like I usually get but a bit of a stream) that was uncharacteristic of my girl. I had started posting this in my long thread but thought it might me more interesting to get this in a single thread. 1976 911S – from garage find to on the road ![]() Here is the noise it was making. This is the noise before taking anything off the car. At first I thought it was a banging but now I feel pretty confident it is an untimely detonation (or hoping...) {FOLLOWUP-NO, rocker arm NOT detonation} Since then, I was able to take off my heat exchangers with little fanfare and had a better look. This is what cylinder 4 looks like from underneath. ![]() This is what it looks like when running from underneath. Interested in all ideas... Notice cylinder 4 doesn't appear to be firing and there is an oil leak very close to that cylinder.
1976 911S; 1957 Mercedes 190SL; 1982 Ferrari Mondial Coupe; 1991 Nissan Figaro; 2001 Panoz Esperante ; 1969 Pitts S1C http://forums.pelicanparts.com/porsche-911-technical-forum/664950-1976-911s-garage-find-road.html Last edited by NeedSpace; 11-27-2016 at 07:16 PM.. |
That sounds like metal on metal. Bad rod? It doesn't sound good sorry to say
Ernie |
Finhead
As mentioned in the other thread, check the rocker shafts/rockers on that bank.
2cam |
Are both valves opening? Does it perhaps have a broken exhaust rocker?
I've heard a bunch of sick 911's over the past 37 years but that's a new one on me
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
NeedSpace,
That is not detonation. Sounds like timing may have skipped - as in cam timing. The cam timing chain may have skipped a tooth. Pull the timing chain covers and see if the chain tensioner on one side has collapsed. Or you could check cam timing on #1 and #4 - it only takes a few minutes on these old cars with nothing in the way. While the valve covers are off, check for broken rockers.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Member 911 Anonymous
Yeap, open the valve covers and look at the rocker/shaft.
You Must CHECK the Rocker Shaft Bolts when you DIY Valve Adjust! Here is the fix: 964 Cams Swap Journey
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Holy crap that sounds EXACTLY the same. Once my kid goes to bed, I am headed out to the car. I'll bet that is it. Hopefully, it hasn't done too much damage.
1976 911S; 1957 Mercedes 190SL; 1982 Ferrari Mondial Coupe; 1991 Nissan Figaro; 2001 Panoz Esperante ; 1969 Pitts S1C http://forums.pelicanparts.com/porsche-911-technical-forum/664950-1976-911s-garage-find-road.html |
I bet it is the lower rocker shaft.
Don't worry, if rocker did not snap, it will just be sitting in the valve cover. Don't worry about oil loss, some will drip out but not much, just be prepared.
Flowing out fluid......
Needspace,
What was that fluid coming out from the engine after the engine stopped running? Gasoline? Do you still have the fuel injection system? Tony |
You guys are the best. I took off the valve covers and sure enough, look what I found!
![]() This is exactly what I DRACO reported on in this link, thanks! You Must CHECK the Rocker Shaft Bolts when you DIY Valve Adjust! Thanks for the reference, this was perfect. ![]() A quick inspection of the rocker arm and the shaft looks like there is no damage. But shouldn't the shaft have 2 gaskets that this is not showing? If so, it could explain a lot of the extra oil I get on my covers that I haven't been able to resolve. ![]() ![]()
No Brother, stock has no seals, the RSR seals is an update/upgrade.
Take a closer look in day light and inspect that Cam Lobe carefully by hand cranking her. Please disconnect the battery ![]() While you are there check all the shafts for possible movement/looseness per my thread above
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 11-27-2016 at 08:41 PM.. |
I am trying to keep my car fairly stock so still using the bosch mechanical fuel injection. That liquid is a whole lot of oil.
ROW '78 911 Targa
It happened to me too 4 years ago....
Finally, back in the game!
Constant Injection System.........
Tony Last edited by boyt911sc; 11-28-2016 at 08:35 AM.. |
Few points on detonation:
Detonation at idle and very light loads is really not possible, you don't have enough cylinder pressures during combustion at these light loads. It's very unlikely to cause detonation at idle no matter how lean you make mixture. Even over advancing ignition won't cause detonation either at idle. These motors are really only detonation prone at loads above 50% to WOT. Glad you found the problem, rocker arm shaft that walked out.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 11-28-2016 at 08:21 AM.. |
RETIRED
An RE agent that knows how to wrench, priceless. Hope it goes back together and no problems.
Good luck.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RE Agent? Actually I am a psychologist...
Black and Blue
this looks like a happy ending!!
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
LOL, he is writing about me's :P. I am a better Agent than Mechanic :-)
