Any tips for adjusting shift coupler?
I just replaced the shift coupler along with the Ball Cup Shift Bushing at the base of shift lever and the Shift Rod Bushing in Tunnel Behind Shifter on my 1983 911 SC.
Now I need to adjust shift coupler. Any practical tips on this adjustment?
Old 12-08-2016, 02:53 PM
jluetjen's Avatar
Follow the instructions of the shop manual.
I suspect that they might be different for the 915 transmission then they are for the 901 in my car, so I'm not going to offer specifics. Doing it any other way will not work -- trust me. As in most things with the 911, diligently follow the manual and it will work. Variations -- less so.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-08-2016, 03:09 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Remove the shifter boot to get a visual of what you are dealing with. Remove passenger side seat, it will help allot to adjust and a helper to hold the shifter in place as you tighten
'85 Carrera Targa
PCA/POC
Old 12-08-2016, 04:24 PM
#147 of 2096
There is a video on YouTube.
Put in neutral, loose the coupler, move the shifter to the left and the coupler to the right.
Tight the coupler and should be there.
At least every time I do it that way works.
Cheers.
#147 of 2096
Old 12-08-2016, 07:25 PM
try this one in youtube
https://www.youtube.com/watch?v=b3nPONBAaZM
Old 12-09-2016, 12:26 AM
Elombard's Avatar
Waynes 101 Projects has a process.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-09-2016, 06:02 AM
ASD ASD is offline
ASD's Avatar
I also had to replace the set screw..after I did the coupler
1999 Carrera2 tip arena red
2000 Boxster S tip...arena red ....black
1981 911sc targa...grey mkt.import...Rosewood
1978 911SC, guards red sunroof delete .much missed
73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead.
Old 12-09-2016, 06:44 AM
It is a bit tricky. Mine has just one small sweet spot to be just right. I have the fancier aftermarket coupler that has no slop at all like the factory coupler does. Spend time to get it "dead nuts" on.
Old 12-09-2016, 07:13 AM
tobluforu's Avatar
Here's a tip, Search, there are probably 500 or more posts on this procedure. Not trying to be a jerk, but it amazes me how some do not use that function which works great!
Old 12-09-2016, 08:16 AM
porsher
aston@ultrasw.c's Avatar
I followed the manual to the letter but the adjustment was off.
I think the defined process steps would work great *if* there was no wear anywhere in the system.
I simply made small adjustments based on feel and crept up on the sweet spot.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 12-09-2016, 11:02 AM
