Question re. repacking new CV joints with grease
I have read here that the grease in the new Lobros is subpar and should be replaced with a higher quality grease. Those of you who have replaced the grease, what is the process you used? Did you clean all of the Lobros grease out or just scoop out what was easy to get to?
1983 SC
Blog
Old 12-13-2016, 11:00 AM
theiceman's Avatar
I remove the joint and wash in soap ( tide ) and water after wiping as clean as I can get with rags. then repack after inspection.
I also use new boots.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 12-13-2016, 11:19 AM
Hi
Targa Me's Avatar
What he said.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 12-13-2016, 11:25 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Now's the time to do it right and get it completely treated with good grease. Take the circlip off the end of the axle and remove the CV. Take a close inspection or picture of how it's assembled/oriented.
To disassemble, rotate the CV so it'll allow the outer section to come free from the inner. Pop out the balls and clean away all the grease. Put the balls back in and put it back together (correctly, so it doesn't lock up, by aligning the wide outer race non-contact area with the narrow inner race non contact area) for regreasing.
This thread shows nice pictures of the inner and outer race orientation CV Joint assembly question
Pack it by hand with the high quality grease of your choice by shoving grease in the voids and rotating the CV as you do it to fill it in and distribute the grease. No need to pile it on or fill the boot with grease. Just use enough to keep a smearing of grease around the operable areas of the CV and that's PLENTY.
Kevin L
'86 Carrera "Larry"
Old 12-13-2016, 11:42 AM
Spiderman
Jesse16's Avatar
Where is this info. about bad grease coming from ? Never heard of "bad or poor quality" grease.
CV grease isn't exactly highly stressed stuff. I would use the black high moly stuff for CV's that has the GKN logo on it and comes in the prepackaged amounts with our hosts CV rebuild kits. You want to use the right amount. As I remember, its cheap and correct.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 12-13-2016, 12:24 PM
Thanks, all. Very helpful. J16, I have come across threads on this forum and on forums for other cars that utilize this type of transaxle e.g., samba, subaru that describe excessive wear or failure with newish cv joints. Some attribute the wear to the grease. Some, to the possibility that the joints weren't articulated properly at the factory so the grease was thoroughly distributed in the joint. And some to poor installation by the owner/mechanic. I don't have any information about the composition of the stock grease or of any other grease, but I thought that since I have a few minutes and a bunch of swepco moly taking up space I'd go the extra yard.
1983 SC
Blog
Old 12-13-2016, 03:02 PM
T77911S's Avatar
pay attention to how the joint comes off the axle, the center part has a ridge that goes towards the shaft. the joint may have a groove on the outside that goes towards the tranny/wheels
also how the cage is oriented in the joint. I do believe there is a front and back.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-14-2016, 04:02 AM
