| Registered Join Date: May 2004
				Well, crud. What did I do now...
			After 3 years and 8 months of mostly procrastinating, I'm putting the engine back in my 1983 SC. Needless to say, after that amount of time, there's a lot of "discovery". And I have a part left over. It's pretty thick, 3-4mm. It seems important. It has a rib welded to one side to make it stiffer. And it was in with my Porsche parts, which are mostly separate from my MGB parts, my Ford 8N parts and my John Deere parts. But not always.  Can anyone identify this? I've look through both of my Wayne books and the Bentley manual, no sign of it anywhere. The only stamping on it says 1130 VE. It had some surface rust, so it was somewhat exposed. I did put a coat of fresh paint on it. I still have quite a bit to bolt back on, like the rear bumper and oil lines... might be from there? I just don't want to have to take the engine back out, once I get it installed. Thanks much! | ||
|  12-31-2016, 11:04 AM |
| Member 911 Anonymous |
			Does it have a part number? It really does not look like a Porsche part Maybe ac mounting bracket?
				__________________ '85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC | ||
|  12-31-2016, 11:18 AM |
| Registered Join Date: Oct 2005 Location: Capistrano Beach, Ca.
			Yes, AC compressor mounting bracket (actually, strut brace.) http://www.autoparts.loc8apart.com/nav/auto-part-alt/Porsche/911/Air-Conditioning-and-Heating/compressors.php
				__________________ L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 12-31-2016 at 11:25 AM.. | ||
|  12-31-2016, 11:22 AM |
			Awesome, I guess it was in there somewhere. And now I can put it on the shelf next to the compressor...  Thanks much! | ||
|  12-31-2016, 11:25 AM |
| Formerly known as Syzygy Join Date: Mar 2008 Location: Calgary, AB
			And maybe label it...
				__________________ Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. | ||
|  12-31-2016, 12:04 PM |
			Yeah, labels would have been awesome. It was only supposed to take a couple months, though.   Making progress! The pile of parts is getting smaller. And my boxer can't wait for a ride.    | ||
|  12-31-2016, 01:27 PM |
| 7.0:1 > 11.3:1 > 7.0:1 |
			Calling for a caption contest
|  12-31-2016, 01:28 PM |
| French Import | Quote:
 Yeah, I did that  .  Just glad I didn't force anything or I would have dented the engine lid.
				__________________ Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!  86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate | ||
|  12-31-2016, 03:08 PM |
| Registered Join Date: Sep 2007 Location: Boston, MA
			I think he should be OK, my SC has the bolt dead center on top.  There is a heater hose that goes up and over the fan shroud that is quite a bit taller. It definitely would have been close if the AC condenser was still in place, but that looks to be on the shelf with the compressor. However, I think the coil might hit the lid - it should go on the other way with the wire pointing down, and most of the body down below the clamp. Mark
				__________________ 1979 911SC Targa | ||
|  12-31-2016, 03:56 PM |
| Registered |
			+1.  Quote:
|  12-31-2016, 04:54 PM |
			The coil is just sitting in the clamp to keep it from rolling around for now. Seems like when I put in the MSD ignition, I read that that coil needed to be installed with the cap pointing up, not down. I had it clamped to the rear engine support before I removed the engine. Still trying to decide where I'm going to mount it after the rebuild. Thanks for the tips though. You guys sure don't miss much! -WE | ||
|  12-31-2016, 08:33 PM |
| Registered |
You need a bumper sticker...  "Boxer on board", it would always be accurate even when the dog isn't with you!
|  01-01-2017, 03:16 AM |
| Registered |
			Good looking pup.
				__________________ '71 914-6 #0372 '17 Macan GTS | ||
|  01-01-2017, 05:04 AM |
