Valve cover tightening torque/and sequence
For the lower 11 stud valve covers anyone know the proper tightening torque and tightening sequence.
It's a 77 911
Also the proper tightening torque for the round sump plate on the bottom of the engine.
Thanx L
Old 08-21-2012, 07:15 AM
na2ub's Avatar
Valve covers are torqued from the middle out, alternating top / bottom. I think the torque is 8 ft-lbs, but not sure. Get a Bently manual.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 08-21-2012, 10:12 AM
ok thanx doug
Old 08-21-2012, 10:45 AM
Chain fence eating turbo
Or think of it as a spiral going outward starting with the inner nuts first if that makes sense.
Old 08-21-2012, 11:16 AM
Peter Zimmermann's Avatar
LINK: How can I feel 6lbs. of torque?
Please pay particular attention to post #21.
Keep the Shiny Side UP!
Pete Z.
Old 08-21-2012, 11:30 AM
88 Carrera, Guards Red
azhodge's Avatar
tightening sequence
For the tightening sequence non of these answers make me feel very good. Is this why so many people have valve cover leaks. Using an oem gasket I would think that the sequence would be something like upper then lower center, upper right next to center, lower left next to center, lower right next to center, upper left next to center. Moving outward. I can't find any reference to sequence in Bentley or wayne. everything on "other engines" taught you torque from center out in a star pattern. and of course for very high torque items like heads you do it in two stages. I can see people starting at one end of the cover and just moving along to the other end. Like I said, if I did not see so much about cover leaks I would say I was being over complicating. ps.. three valve adjustments and I have never had a leak on my 88. tear me up...
Old 01-16-2017, 03:34 PM
sugarwood's Avatar
Just keep in mind it's not a pressurized seal. That is all you need to know.
I think I read somewhere in here that you just turn until it stops, and then maybe a very light tug.
With a tiny 1/4" ratchet, you don't generate much torque to overkill it.
1986 Bosch Icon Wipers coupe.
Old 01-16-2017, 05:14 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Go over the nuts several times to insure they are snugged to torque spec
+1 get a 1/4" drive torque wrench if you plan to diy your valve adjust
Old 01-16-2017, 07:55 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Exactly - just hold the ratchet with your thumb and a couple fingers and it's a pretty big feat to actually over-torque such simple fasteners (assuming use of original-style, paper gaskets here).
Dracholio, you actually use a torque wrench for fasteners like those - holy jebuz, I didn't think you were such a noob?!?!?!
Old 01-16-2017, 08:00 PM
azhodge's Avatar
So...why so many comments about reoccurring, persistent leaks. it can't be layed at the feet of warped covers.
Old 01-16-2017, 08:03 PM
My guess is that it is from people being too lily-livered with their tightening torque (aka - not getting them tight enough after reading about the original, dainty torque specs), so the gasket gets wet and then no amount of further tightening stops leakage after the fact - similar in a way to how people experience rocker shaft walking when tightening old fasteners/shaft assemblies to original "new" torque specs (not nearly enough torque for old, used gear).
Old 01-16-2017, 08:12 PM
DRACO A5OG's Avatar
LOL, Old Noooooooob
'85 Carrera Targa
PCA/POC
Old 01-16-2017, 09:37 PM
/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
In ~40 years of existence, several owners and varying degrees of skill/attention to detail from said owners or mechanics, the valve covers can easily be bent. I am guessing Turbo valve covers are a popular upgrade because of this. Doesn't matter what tightening pattern you use if the covers aren't true.
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 01-17-2017, 06:13 AM
T77911S's Avatar
get a die die and clean the threads really good.
also use the reusable gaskets and just snug them. if you think they are tight enough then they are too tight. if the gasket squeezes out they are too tight.
they are WELL worth the money
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-17-2017, 07:48 AM
