AEM AFR and Voltmeter Gauges Install
I'm a serial lurker, and have certainly taken much more from this forum than I've given it, but thought I'd share a pic of my AEM gauge install. In typical fashion for me, I started out wanting to add a voltmeter because I followed Jack Olsen's lead and installed a Battery Tender LiFePo4 battery and wanted to monitor the charging. So I ordered the AEM voltmeter and Rothsport clock delete plug.
But then I got thinking that if I put the voltmeter where the clock was, I won't be able to put anything else there, like an AFR gauge. In my mind, it's better to have an AFR gauge near your line of sight than it is a voltmeter. So I decided the drill a 2" hole in my perfectly good Rennline lower dash and mount the voltmeter there, and drill another 2" hole in my perfectly good clock delete plug for an AFR gauge.
Major thanks to Salcarceller, who I contacted for some advice about the O2 sensor wiring. I was afraid the 8' harness for the O2 sensor was going to be too short to go from the engine compartment through the interior into the frunk and then up to the rear of the gauge panel but I actually ended up with probably a foot of wiring to spare.
One word of advice, though. The AEM gauges can be programmed with various backlit colors to match different instrument lights and the default is red. To change the color you have to insert a jeweler's screwdriver into a hole in the back and turn an adjuster. The point is that if you can do this before the gauge is fully installed it'll probably be easier than doing it afterwards, where space is usually minimal.
Jeff
Old 02-05-2017, 11:32 AM
Administrator
Dmitry at Pelican Parts's Avatar
Thanks for sharing with us Jeff - did you happen to do a write up for the install? If so, you may be interested in becoming a DIY Project Expert. If we end up publishing your article to site, we'll give you 10% off your next order. Check out the link below if you're interested!
Enthusiast Tech Article Submissions - Pelican Parts
-Dmitry
Old 02-06-2017, 11:51 AM
Flyin' blind
Great work Jeff!
I am planning on doing the same thing this week. Could you post some detail with pics on where you ran the wiring?
Thom
Thom
89 Coupe
Old 02-06-2017, 01:01 PM
There aren't many A-pillar mounting options. Here's an A-pillar gauge mount available on eBay. No drilling. The mount clamps onto the A-pillar profile; the gauge cup of choice attaches to it.
Sherwood
Old 02-06-2017, 05:21 PM
Jeff, I've got the exact same gauges. I'm going to mount mine in the console where the air conditioning switches used to be - pictures will come when done. Where did you route your wiring for the O2 sensor? I'm doing that job next so would like to see what you did.
Mark.
84 911 Targa Carrera currently getting renewed
Old 02-06-2017, 08:54 PM
Do you have the name of the seller of the A pillar mount? Thanks
Scott
87 Carrera Venetian Blue gone but not forgotten.
Old 02-07-2017, 04:55 AM
scarceller's Avatar
Jeff,
That install looks great!
If you have a 84-89 Carrera I can share a document I have on gathering AFRs for the 3.2L motor. This doc outlines 7 test cases I use to access the health of a 3.2L motor. I developed these 7 test cases after years of looking at AFR readings on healthy motors. Even if the motor is not a 3.2L you can still use these basic tests on other engines like CIS but readings will run about -0.5 richer
You already have my email.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-07-2017, 05:50 AM
scarceller's Avatar
Route the wiring via the main engine harness access hole, it's located under the rear drivers side jump seat. If you are sitting in the rear seat it's directly behind your left heel. Lift the carpet in that area and you'll find the large DME to Engine harness as it goes through the firewall in that location. Run the harness from outside into the cabin, meaning you will route the small connector end of the harness that plugs into the gauge, start under the car and push that small connector through that large rubber grommet. You may want to pull the grommet out of the tin from inside the cabin, then get the gauge harness through the grommet and reinstall the grommet.
Enjoy!
Mark.
Sal
1964 356SC (SOLD)
Old 02-07-2017, 06:01 AM
Flyin' blind
Enjoy!
Thanks for the tip Sal. I hope to have my components installed by the weekend and will also be contacting you soon for the data collection log.
Thom
Thom
89 Coupe
Old 02-07-2017, 07:13 AM
scarceller's Avatar
This thread is also helpful for ideas on mounting
AEM Wideband O2 gauges
Sal
1964 356SC (SOLD)
Old 02-07-2017, 08:07 AM
Thanks for the wiring route details Sal. Will be easy as my interior is all out at this moment. I just have to get some time to put it up on the hoist so i can access the grommet from underneath. Please send the document with the 7 tests to my email - you and I have messaged before so I'll PM you the email address. The plan has always been to get the gauge in the car, do the testing, then buy your DME upgrade and new injectors. We'll make that happen this summer for sure.
Mark
Old 02-07-2017, 10:12 AM
This is what I used for my AFR and voltmeter. AFR is the bottom instrument. It records up to 2 hours of data and you can download it to your laptop with the mini USB port in the front on the lower left and then chart it or make an Excel spread sheet. I records AFR, RPM, and manifold vacuum/pressure. Our host sell this kit.
The "CL" reading on the gauge is for "cold" meaning the wideband sensor is not warmed up yet.
Above digital readout is battery voltage, oil cooler temp, free air temp, and a digital clock. The toggle switches let you toggle through the settings and set the clock.
I cannot over emphasize how critical it is to record AFR, RPM, and MAP data and be able to analyze it later. to me, real time gauges with no data memory is a waste.......unless you have a co-pilot with a clipboard who can take notes really really fast!!!!
I have had this setup in my MFI 2.7 1973 for many years and it has been invaluable in setting the AFR.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 02-07-2017, 12:36 PM
This is a quick mock up of what I have in mind. I need to get the vinyl stretched a bit but I think the idea is clear.
Old 02-08-2017, 09:25 PM
scarceller's Avatar
Lake Guy,
That's really nice super clean install!
Sal
1964 356SC (SOLD)
Old 02-09-2017, 06:31 AM
Scott
That product is no longer on ebay, but I found one source:
Porsche 911 pillar pod gauge kit - 9xauto
Not at a friendly price. However, the unique profile of the early 911 A-pillar provides minimal options.
Old 02-09-2017, 09:03 AM
Burnin' Rubber
Koizumi's Avatar
Dang, when that was available on eBay, it was less than half of that asking price!
Old 02-09-2017, 10:21 AM
Under the radar
Trackrash's Avatar
Really nice install. Makes me wish I had a console. My gauge arrives today, time to get busy.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-09-2017, 10:58 AM
less than professional but it gets the job done .
-dampened vdo ampmeter
-lightweight 911 GT LM guage surround (coors light beer can with high speed carbon fiber vinyl wrap)TM
1979 SC
1986 Carrera 3.6 L+
Old 02-09-2017, 05:35 PM
Hey guys,
Sorry for the delay in responding to some of your questions, but it was a busy work week.
First I ran the wiring along the inner wheel well and secured it so it wouldn't get snagged on anything. You can see how big the harness connector is. I also wrapped it to keep dirt and grime out.
Sal had suggested running the wiring from the O2 sensor through the large grommet in the LH rear seat footwell area, which you can see part of in the lower right of the next photo. I initially tried that but decided to find another solution because the connector that goes into the back of the gauge is rectangular and has small tabs on the ends, so I was concerned about possibly breaking it while trying to force it through what is already a tight grommet. And because I was worried about the cable not being long enough, I wanted to run the wiring up the center of the car and not on the LH close to the door jamb like Sal did because my gauge is closer to the center of the car. So I drilled another hole and then added a grommet and silicone sealer:
Then I ran the wiring through the LH inner seat rail and up to the pedal cluster. Because I have removed the A/C, I was able to run the wiring through an existing hole in underneath the dash into the smuggler's box and then out to the back of the dash in the frunk. (Please excuse my loose under dash wiring. I've removed a lot of interior components, like the center console and original dash, but am trying to keep most of the wiring for the time being.)
After test driving the car, I agree with Dick that the value of an AFR gauge is seriously diminished without a data logger. The nice thing about the AEM gauges is both the voltmeter and AFR gauge have wires in the harnesses that can be connected to a data logger. Mine are not being used now, but I expect that'll change in the future.
Old 02-11-2017, 07:34 AM
Jeff,
Yes, my car is an '86, Al, and I'm just getting to the point in my ownership where I'm starting to want to learn about tuning the engine. I've been fortunate that the engine has run very well since I bought this car a few years ago, but I'm sure it could be better. So if you could send that document I'd be most appreciative.
Jeff
Old 02-11-2017, 07:39 AM
