Do my RSR Struts need strut spacer and O-ring
I am putting front suspension together and struggling with this...
I see this part:
and the O ring"
Here is pic of my strut, I do not see a grove for the O ring and not sure if the RSR strut uses the spacer?
Old 02-08-2017, 03:50 AM
proffighter's Avatar
There is no groove, but space on the backside of the bearing race (what you called spacer) for the o-ring
Roland
930 Turbo '81 Too many modifications to list
Old 02-08-2017, 05:03 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Agreed with Roland. The o-ring just packs the space between the radius of the spacer and the radius of the spindle. it's there to help reduce the migration of oil along the spindle when the grease thins or separates.
The spacer is technically not a bearing race. I think it's actually a collar that definitely provides the sealing surface for the grease seal and I believe it also serves as a stop or thrust for the inner race of the wheel bearing?
Kevin L
'86 Carrera "Larry"
Old 02-08-2017, 08:16 AM
Correct, it's the race spacer, see here no.39. Shaft seal is no. 21 (which seals on spacer):
Roland
Old 02-08-2017, 01:06 PM
