-   -   Motor overhaul and update with Sleepers Speed Shop (ITB's, AEM, etc) (http://forums.pelicanparts.com/porsche-911-technical-forum/945555-motor-overhaul-update-sleepers-speed-shop-itbs-aem-etc.html)
911 jared 09-07-2017 01:37 PM
yeah i guess your off to a good start...
not bad.
Ryan H 11-15-2017 01:43 PM
Originally Posted by BE911SC (Post 9729062)
Any updates? Saw this thread in the recent Pelican email.
Finally some updates. The last couple months have been crazy at the office and at home. Work, travel, kids sports, etc.
There's actually been quite a bit going with the car, but very sporadic and out of order.
The car is finally with my good friend Willy who's an amazing painter. He can do custom stuff and full restorations. I honestly cant say enough good things about the guy.
It's now completely gutted.
http://forums.pelicanparts.com/uploa...1510785531.jpg
The engine compartment has been stripped. Danny at Sleeper's welded in Tarrett shock tower reinforcements, as we'll be running coilovers.
http://forums.pelicanparts.com/uploa...1510785690.jpg
The sunroof was bugging me, and all that garbage weighs a bunch, so we we plugged it.
http://forums.pelicanparts.com/uploa...1510785723.jpg
Reiver 11-15-2017 02:29 PM
I really like to see young guys working on aircooled 911's...lots of the old guys are or have retired...
Those bearings look good...how many miles on the lump? 3.0's have a deserved bottom end longevity rep.
I'd delete my sunroof in a NY minute too.....
Ryan H 11-15-2017 02:38 PM
Only about 120k.
Reiver 11-15-2017 02:47 PM
Originally Posted by Ryan H (Post 9816151)
Only about 120k.
...sat for a bit....I'm told more studs are found broken on low mileage cars...many driven short distances and never properly warmed up.
My 930-16 had good bearings at 230K when I traded it out for a 930-10.
Was that tig or mig on the sunroof delete? That looks like it came out without any warping.
Flojo 11-16-2017 05:16 AM
Originally Posted by Ryan H (Post 9509777)
...and we assemble a badass 3.0!
I already envy you SmileWavy
Ryan H 11-16-2017 07:17 AM
Mig welded.
My buddy tore his 3.0 down a couple months ago with 210k and the bearings were fine too. It's crazy.
Reiver 11-16-2017 07:37 AM
Originally Posted by Ryan H (Post 9816787)
Mig welded.
Nice welding job....I really want to delete that whole weighty thing...did you weigh all of the mechanism btw?
As to the bottom end that is crazy good.
75 911s 11-16-2017 10:25 AM
Maybe this will help Reiver
I came up with about 33lbs on my semi accurate scale when I weighed the entire cassette, motor, rails, pretty much everything from the sunroof.
http://forums.pelicanparts.com/uploa...1510860281.jpg
KTL 11-17-2017 09:11 AM
Ryan,
Make sure to have the shock tower/bridge member welded at the corners where it meets the unibody structure. You need to beef up that joint with plate steel because it wants to pull away from the longitudinal structure. Right now you're only reinforcing the top of the damper "tubes" with those Tarett gussets, which basically prevent the coilover from punching through.
This link has some good info in it and notice the link in my post where BarryJB shared some good pictures of the damage that coilovers can do to the bridge member.
http://forums.pelicanparts.com/porsche-911-technical-forum/794363-rear-shock-tower-reinforcement.html#post7886086
Reiver 11-17-2017 09:13 AM
Thanks....that is 33 lbs I'd like to see go to weight watchers...especially up high like that.
Ryan H 11-17-2017 10:02 AM
Originally Posted by KTL (Post 9818187)
Ryan,
Thanks and will do!
Fabspeed Motorsport 11-17-2017 01:48 PM
Coming along nicely Ryan!
Ryan H 11-17-2017 02:29 PM
Thanks! It's getting fun again after a bit of a layoff.
Quick update. I sent the cylinders to Gary at Torque Power Engines to have them checked and honed. Good to go!
http://forums.pelicanparts.com/uploa...1510961339.jpg
Ryan H 11-20-2017 11:34 AM
More progress...
Interior almost completely stripped
http://forums.pelicanparts.com/uploa...1511209908.jpg
Pedal set will get restored
http://forums.pelicanparts.com/uploa...1511209942.jpg
Gas tank out and most of the odds n ends gone. Plan to run a battery in the smugglers box
http://forums.pelicanparts.com/uploa...1511209993.jpg
Details...
http://forums.pelicanparts.com/uploa...1511210018.jpg
Ditching everything. 2100lbs or bust
http://forums.pelicanparts.com/uploa...1511210055.jpg
Ryan H 11-27-2017 08:30 AM
Pretty much a bare shell as of today
http://forums.pelicanparts.com/uploa...1511803847.jpg
Ryan H 12-08-2017 12:40 PM
This was fun..
http://forums.pelicanparts.com/uploa...1512769208.jpg
mikl911 12-08-2017 12:43 PM
Brave soul.
KTL 12-08-2017 01:18 PM
The amount of wiring is shocking, isn’t it?
Please don’t throw that away. There’s a lot of useful plugs and terminals and other stuff people can use
senna21 12-08-2017 03:38 PM
Just because you can, doesn't mean you should. Reliability and performance go hand in hand and in that order.
