Diss Member
Reference sensor connectors. Source?
I'm trying to find the part numbers and a source for both the male and female connectors for the 3.2's flywheel reference sensors.
I want to connect a temporary tap to pull the signal for some data logging and a short extension with a male and female on either end would make it easy in, easy out.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
don't know the PN's but this should help
AMP Connectors/Terminals
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Junior Power Timer connectors
Here is a link to buy from.......
https://www.bmotorsports.com/shop/product_info.php/products_id/3413 Their part # for the two complete kits are as follows, these connectors are the type that don't use the rubber boots. CONN-75854 CONN-75853 Hope this will help. |
Diss Member
So it looks like everyone is all selling the TE Connectors #282191-1 as the female connector. (Interesting that Mouser lists it as "Male" when the attached PDF clearly shows it as female.)
The drawing shows the male connector as "Counterpart" and it lists every spec except the part number. ![]() On the TE Connectors site they only show a 2 connector ("2 position") male. Any other number of connectors only shows the female "splash proof" connector. No one lists the other connector under "customers also purchased" either. Weird... (Wonder where the "Junior Timer" name came from?!)
I would love to know - it would be an interesting piece of esoterica for a geek like me. I don't know the full history, but back in the day, there were 4 major connector mfrs that I was aware of, 4 that my line of biz dealt with exclusively. We just called them A, B, C, & D (Amp, Bendix, Cannon, and Deutch). There were certainly more. Over the years, TYCO bought up a lot of the ones that were still around. TYCO became TE. This info is just from my faulty memory. The same thing happened in the discrete part industry - I did a memory dump, but I think IRC (resistors) was bought by vishay I think for example, and companies bought out each other and I stopped keeping track since it became an avalanche. Junior Power Timer was (is?) an Amp product known by the acronym JPT. The industry used s-loads of acronyms, and the guys that remembered them all became local go-to guys in my work. I suspect that the part was made (and named) for one particular application, and then other industries found they could use them for alternate applications. Maybe Gerry (86 911 Targa) knows. The male / female part locating on the web-site is infuriating. when I was a pup, I could call an Amp rep who would only deal with me, and I would get my answer. Now, you wonder if you missed something or if they got it wrong (probably). Sorry, gotta go chase some kids off my lawn. :-)
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue Last edited by steely; 02-19-2017 at 06:36 PM.. |
ROW '78 911 Targa
Wagner Alternators and Supplies, Inc.
Search these part numbers and look at the photos of each: Female 3 pin housing 192148 (in stock) Female terminals 191551 (in stock) Male 3 pin housing 193241 (Out of stock) male contact pins 192156 (in stock) Must set up an account to buy. If you want me to order some (likely 50 to 100 each min) let me know (PM, or email) and we can work something out. Likely 6 weeks or more delivery from Europe
Diss Member
Searching the Chief Enterprises number for the male connector gave me a link with a number of interchange numbers!
BOSCH 1 928 402 452 MERCEDES-BENZ 034 545 39 28 MERCEDES-BENZ A 034 545 39 28 RENAULT 77 03 297 048 SIEMENS 1701002788 SIEMENS 2260345453928 The Bosch number seems to check out. Nexus Electronics lists that they stock it and they are close by in Chino... And just for fun that Bosch number pulls up Bosch 1 928 402 579 and 1 928 402 412 as the female connector. (The difference seems to be 1 928 402 412 is cheaper and has a boss on the side so it can be slip mounted on a metal tab. Wouldn't make a difference besides the slightly non stock look.)
I find connectors like this in the U-pull-it junkyards, usually from BMW's as the Porsche section is often missing.
I have made the exact adaptor you are describing! Chuck.H '89 TurboLookTarga, 427k miles |
Wayne - can you elaborate on how you're planning to buffer the signal(s)?
Diss Member
No buffer. Just a tap to an ADC.
Diss Member
Found the design drawings on the Bosch Connectors website.
If you filter the "Product Family" by "Jetronic" they will pop right up. Explains a lot of the nomenclature such as "Code 1" and shows a bunch of other options in case you want to build something stock looking with different wire counts.
Member 911 Anonymous
Nice :-)
I had to rebuild mine using fuel injector spades when my ref sensor wire pulled out. Lesson, do not pull on the wires.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Just to add options, I like these guys but I don't see the 3 pin male. They do have the boots
-Dave in Minnesota 96 C4 Cab, 85.5 944 82 SC Targa SCWDP #0023 82 928 67 912 60 T-5 B Cabrio |
Diss Member
Turns out that Chief Enterprises in Illinois is the North American distributor for Bosch Connectors. I called Nexus Electronics locally and they had the connectors in stock and would will-call them but they had a $50 minimum order so I'll just wait a few days...
$2.96 each which includes the housing, the crimp connectors, and the boot. Seems like a bargain!
Diss Member
Turns out that the Bosch 1 928 402 452 and 1 928 402 579 numbers are only for the connector housing even though the picture shows all the parts.
Here as a complete Bosch part number list including some options: Female - Bosch connector housing
