Broken wheel on window regulator
Removed the power window regulator from my euro 911SC today to replace the outer spring retainer. The broken piece was in the bottom of the door and I could see that it was missing from the regulator. That fix is well documented on this board.
But I found another problem -- the rear plastic wheel had broken. See picture. The broken piece was stuck in the grease in the extreme rear of the channel at the bottom of the window. Does anyone know of a source for this plastic piece??
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Regulator wheel.
The regulator may have to be replaced. Perhaps, someone will chime in. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Member 911 Anonymous
It is kinda ghetto but I fixed my 190E's regulator with a screen door wheel that matched the OD. Drilled it out and bolted it on, worked great but will not pass concours :-(
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 02-24-2017 at 08:24 AM.. |
They will have that type of wheel at Lowes or HD, Ace Hardware, or on the C R Lawrence website.
LOL, break a leg brother!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
And lo' and behold, up popped the 928 roller at *********. No dimension given, but it sure looks the same as mine. PET carries it too with the bolt (rivet?) to hold it in place (4 and 5).
Thanks again for the help. |
