pete917's Avatar
Originally Posted by Turbo1987 View Post
This is my '87 Tribute
Russ
Beautiful
Pete
Porsche, there is no substitute!
911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv
Old 02-01-2012, 04:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1001 (permalink)
hi, sorry if it has been posted earlier in this thread...it is a long one..
has anyone seen a version of this rear bumper conversion, made to suit a narrow bodied car....I have a 1977 911S, i would like to convert the bumpers, but am not keen on cutting out the rear wheel arches. Thanks if anyone can elaborate.
Tony
Old 02-02-2012, 01:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1002 (permalink)
Tony
Never seen a Ruf rear bumper for narrow bodied cars. In fact, I suspect that at least some of the bumper caps for SC bodies are actually lifted straight from a real Ruf bumper - and thus require work to make the extra 1" flare blend in.
'77 S with '78 930 power and a few other things.
Old 02-02-2012, 03:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1003 (permalink)
understood, thank you.
technically, I could buy the rear bumper I see in the photo above, and alter it (by reducing its width, feddling it....) to suit, and viola!!!.....a ruf rear bumper for a narrow body 911.
This solves a dilemma for me actually..as I want to alter my 77 911s to clean up the front and rear bumper design to something akin to what RUF did, but I don't want to do work that can't be undone (i.e. widen the rear).....
I suspect the result will look 964ish, which isn't bad. and when i want to change it back, should be no problem.
excellent....think I will have a beer. cheers
Old 02-05-2012, 01:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1004 (permalink)
btw, beautiful car, Turbo1987
Old 02-05-2012, 01:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1005 (permalink)
I found this thread invaluable, so I thought I'd add my own contribution. I've just put MA Shaw Ruf bumpers on my old girl - here's how it turned out:
(Door slightly ajar, not crappy shut lines!)
I don't actually dislike the normal impact bumpers, so I wasn't too sure about the front bumper, but I quite like it now it's on.
The worst part of the process was bolting up the front bumper to the wings, particularly on the oil cooler side. It's a sod getting your hands up there, past the horn trumpets, to get the spanner on the nuts. I tried to use rivnuts, but it was tricky getting them to line up perfectly with the bolts and the rivnuts ended up spinning, rendering them useless. So I drilled them out (be careful not to go through the top of the wing!) and just used short allen head cap bolts.
Looks pretty good in the metal/plastic though. Just need a 300 bhp 3 litre screamer in the back now!
Old 03-24-2012, 11:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1006 (permalink)
jsveb's Avatar
Absolutely beautiful.
My carrera 3.0 will look like that, when I am done.
What color is it? Mine used to be oak green, I think. Will be going back to original color and Ruf Bumpers Maybe even a Duck tail.
Old 03-24-2012, 11:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1007 (permalink)
Mine is Moss Green. I think it's slightly lighter than Oak Green. Looks nice in direct sunlight, looks almost black otherwise.
Old 03-24-2012, 11:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1008 (permalink)
Looks awesome Northy.
Old 03-24-2012, 02:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1009 (permalink)
pete917's Avatar
Very nice Northy! Great work.
Pete
Old 03-24-2012, 02:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1010 (permalink)
Send a message via AIM to NoLift911
How did you get the slots in the rear?
Jeff
Old 03-25-2012, 05:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1011 (permalink)
The bumpers were second hand and the slots had already been cut. As I understand it, they had been done by hand by the PO.
Old 03-25-2012, 08:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1012 (permalink)
Sorry if this has been asked, I haven't yet had the time to read all 50 some odd pages.
Does anyone make rear flares. I know they aren't a huge difference over the stock.
I would like them bit wider but not as wide as a turbo car.
Cheers,
Scott
Old 07-12-2012, 07:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1013 (permalink)
Bill Verburg's Avatar
Cheers,
Scott
Ruf flares were 1" wider than SC/Carrera they were built up by cutting and welding in a strip of metal
SC/Carrera are 9"
Ruf are 10"
930 are 11"
Bill Verburg
Old 07-12-2012, 08:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1014 (permalink)
Thanks for that Bill.
Old 07-12-2012, 11:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1015 (permalink)
Bill,
Sorry, but I gotta disagree. I have done the CTR setup and it is costly and a LOT more work than I expected. The CTR flare is only 1", correct. But the flare extends down all the way around with a very different lower level and requires a substantially modified [or Ruf $$$] rocker as well as a different rear bumper to fit correctly.
You can do a simple weld up to approximate the old factory 9" flare but if you are trying to attain a correct Ruf look it is a lot more work.
Good luck.. money will flow like water to get it right!
JohnR
Old 07-12-2012, 11:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1016 (permalink)
Mr. C
SAY - 642's Avatar
Ultimate RUF Conversion
Originally Posted by alwaysflat6s View Post
Bill,
JohnR
Thought I'd keep this thread going...
Just like this...NOS RUF CTR Flares to accommodate 10 x 17's
Old 11-20-2012, 11:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1017 (permalink)
Would love to see more pics from other angles. Looks amazing!
Old 11-20-2012, 11:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1018 (permalink)
Mr. C
SAY - 642's Avatar
It's just a teaser (still a work in progress)...All work by Peter Dawe as mentioned here
Old 11-20-2012, 12:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1019 (permalink)
pete917's Avatar
Looks fabulous!
Pete
Old 11-20-2012, 01:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1020 (permalink)
