Jeffreypang911's Avatar
Wiring gurus - Help identifying this Relay
The one on the left is the flasher unit. But the one on the right?
Both are near the bulkhead, not on the relay box.
Also found this guy - not original Porsche obviously but this is wired inline to my power windows. Is it a fuse? Someone rewired the entire power window circuit and all the power goes through this thing. If so ill just remove it and run it through the original fuse box.
Old 04-21-2017, 10:32 AM
dlagerstrom's Avatar
What year are we talking about?
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 04-21-2017, 12:28 PM
Bottom photo looks like a circuit breaker.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 928
Kroon Wire Harnesses
Headlight flasher change over relay.
The relay socket on the right is the headlight flasher change over relay.
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 04-21-2017, 02:24 PM
Walt Fricke's Avatar
Jeff - etiquette calls for identifying the model of your car, and for good reason. In this case, also identifying whether you are talking about stuff under the dash, in the engine compartment, or, as is likely, in the trunk or behind the dash up front.
Gerakroo sounds like a guy who knows a whole lot more about all the 911 wiring harnesses over the years than the average owner - which is great, but you can't count on someone with that much very specialized knowledge reading every post.
For a guy like me to make an intelligent answer, I'd have to get out the wiring diagram for the appropriate year, and then use the wire color codes to identify the relays. Without knowing the year, I'd never bother.
It seems like it would be worth your while to get access for a wiring diagram for your model, given that a previous owner fiddled around with the wiring, which you are now trying to understand. You may find some more surprises.
Old 04-21-2017, 04:26 PM
ROW '78 911 Targa
timmy2's Avatar
Gerald nailed it. (As he should)
But as Walt mentioned, Post the year of your car when asking questions.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-21-2017, 04:43 PM
Oops! Sorry my bad. I don't know how i missed that - its a 1974 911s.
Thanks for the replies everyone. I managed to source the schematics through someone in the forums - Ill dig a bit deeper myself. Just trying to understand and label everything incase something goes wrong in the future. Never heard of a "Headlight" flasher change over relay before - what is its function?
Old 04-25-2017, 03:52 PM
Yes that is Pasha cloth
redstack's Avatar
The lower one is probably a auto resetting breaker, it trips off then resets once it cools. Probably put in when someone had an issue with the power windows.
I've seen them in a house charging circuit on my RV.
84 RoW, slicktop coupe, with Pascha baby!
08 GTS Cayenne
Old 04-25-2017, 07:40 PM
