LinkBack Thread Tools Rating: Thread Rating: 3 votes, 1.00 average.
THE REDNECK MEXICAN
riverstonefly's Avatar
Help car stays running after pulling key
Ok fellas I just had the retro fuse relays from our host installed today by a reputable Auto electric shop and after picking the car up everything was working fine. I decided to take a quick drive after work this evening but only made it a 1/4 mile when the car just shut off! I pulled into a vacant lot and it fired right up so I figured Id head back to the garage and upon arrival I turned the ignition switch off and pulled the key out but the car stayed running! The only way to shut the car off was by popping the clutch but the pump and alt light stay on so I disconnected the battery.
Please help
JR
Old 04-27-2017, 07:41 PM
ROW '78 911 Targa
timmy2's Avatar
What year car? Do you mean the replacement fuse panel with headlight relays?
It sounds like maybe the shop screwed something up or your ignition switch electrical has failed.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-27-2017, 09:47 PM
Titanium User
By any chance is your foot on the brake?
Old 04-27-2017, 10:24 PM
THE REDNECK MEXICAN
1980 and yes the retro ato fuse relay kits sold by our host.
Sent from my XT1650 using Tapatalk
Old 04-27-2017, 10:37 PM
THE REDNECK MEXICAN
To be honest I can't recall?
Old 04-27-2017, 10:38 PM
Titanium User
Same thing happened to me - but if I took my foot off the brake the car would shut off with the key out. Took me a while to figure this out because you're used to having your foot on the. Take when the car is parked. There was a bad ground in one of my front turn signal housings. Which would also illuminate when the brakes were pressed. I cleaned up the connections in my front driver turn signal housing and made sure everything was grounddd correctly and it fixed my issue! Try it in the garage with the lights off so you can see if the turn signal illuminates.
Old 04-28-2017, 06:00 AM
Jonny H's Avatar
There are no reported issues with our fuse panels and we have over 300 units installed across all model years.
It does sound like either a wiring error or a ground issue.
www.classicretrofit.com
Old 04-28-2017, 07:12 AM
THE REDNECK MEXICAN
Tried the brake and car still stays running, also my blower is no longer working.
Old 04-28-2017, 09:46 AM
THE REDNECK MEXICAN
I have complete confidence in the product sir just asking if anyone else experience the same issue after the swap, hoping it's something simple.
Jr
Old 04-28-2017, 09:48 AM
THE REDNECK MEXICAN
Update
It's all good
Old 04-28-2017, 06:21 PM
Science is NOT optional
rbogh901's Avatar
Update
It's all good
And so it was a bumped ground during fuse bank install or...? Is the watch a clue?
PCA member since 1993
Old 04-28-2017, 08:35 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Pull the handbrake up and see it if cuts off.
Marc
Old 04-30-2017, 07:33 AM
So what made it 'All good'? Was it 'FM'?
Old 04-30-2017, 08:07 AM
rbogh901's Avatar
Would that indicate a grounding problem in the emergency brake light circuit?
Old 04-30-2017, 11:44 AM
Sure would be nice to hear what the answer to the prob was.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 04-30-2017, 11:52 AM
rattlsnak's Avatar
Originally Posted by rbogh901 View Post
With that indicate a grounding problem in the emergency brake light circuit?
Diode.. See this thread..
Weird 76 electrical issue - headlights on engine won't turn off/speedo light braking
Marc
Old 04-30-2017, 02:40 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Issue.
I agree!!
Nothing worse than not posting the resolution
to one's posted issue......
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-30-2017, 02:44 PM
rbogh901's Avatar
Thanks rattlesnake. I tried to chase this in my 1977 but couldn't find anything that looked like a diode holder in the dash behind the speedo. Also, my fuel pump keeps running so must be on that circuit as well. Did 77 have a diode in their Dash wiring and if so where do you look?
Old 05-01-2017, 10:13 AM
rattlsnak's Avatar
I have looked for it on a few cars and have never found it. Doesn't matter anyway, if it's bad it just acts like a normal piece of wire so to speak. You can just splice in a new one behind the gauges.
Marc
Old 05-02-2017, 05:16 PM
Banned but not out, yet..
RSBob's Avatar
Reading between the arm hairs, I believe the skullified knife and maybe the watch were lodged into the fuse panel creating the issues. Or maybe it was the key fob, or a comet. Definitely X-files stuff.
Old 05-02-2017, 08:50 PM
