THE REDNECK MEXICAN
Help car stays running after pulling key
Ok fellas I just had the retro fuse relays from our host installed today by a reputable Auto electric shop and after picking the car up everything was working fine. I decided to take a quick drive after work this evening but only made it a 1/4 mile when the car just shut off! I pulled into a vacant lot and it fired right up so I figured Id head back to the garage and upon arrival I turned the ignition switch off and pulled the key out but the car stayed running! The only way to shut the car off was by popping the clutch but the pump and alt light stay on so I disconnected the battery.
Please help JR |
ROW '78 911 Targa
What year car? Do you mean the replacement fuse panel with headlight relays?
It sounds like maybe the shop screwed something up or your ignition switch electrical has failed.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 04-27-2017 at 09:50 PM.. |
Titanium User
By any chance is your foot on the brake?
THE REDNECK MEXICAN
![]() Sent from my XT1650 using Tapatalk |
THE REDNECK MEXICAN
Titanium User
Same thing happened to me - but if I took my foot off the brake the car would shut off with the key out. Took me a while to figure this out because you're used to having your foot on the. Take when the car is parked. There was a bad ground in one of my front turn signal housings. Which would also illuminate when the brakes were pressed. I cleaned up the connections in my front driver turn signal housing and made sure everything was grounddd correctly and it fixed my issue! Try it in the garage with the lights off so you can see if the turn signal illuminates.
There are no reported issues with our fuse panels and we have over 300 units installed across all model years.
It does sound like either a wiring error or a ground issue.
www.classicretrofit.com |
THE REDNECK MEXICAN
THE REDNECK MEXICAN
Jr Sent from my XT1650 using Tapatalk |
THE REDNECK MEXICAN
Update
![]() It's all good Sent from my XT1650 using Tapatalk |
Science is NOT optional
And so it was a bumped ground during fuse bank install or...? Is the watch a clue?
PCA member since 1993 |
Insert Tag Line HERE.....
Pull the handbrake up and see it if cuts off.
Marc |
So what made it 'All good'? Was it 'FM'?
Would that indicate a grounding problem in the emergency brake light circuit?
PCA member since 1993 Last edited by rbogh901; 05-03-2017 at 11:55 AM.. |
Sure would be nice to hear what the answer to the prob was.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Weird 76 electrical issue - headlights on engine won't turn off/speedo light braking
Marc |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Issue.
I agree!!
Nothing worse than not posting the resolution to one's posted issue...... Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I have looked for it on a few cars and have never found it. Doesn't matter anyway, if it's bad it just acts like a normal piece of wire so to speak. You can just splice in a new one behind the gauges.
Marc |
Banned but not out, yet..
Reading between the arm hairs, I believe the skullified knife and maybe the watch were lodged into the fuse panel creating the issues. Or maybe it was the key fob, or a comet. Definitely X-files stuff.
An air cooled refrigerator. ‘Mein Teil’ |
