Tire & Fender Contact
So guys I have a dilemma, 87 930 RoW euro ride height. Went to RUF 10" in back with255/40-17 & 15mm spacer all good. Front is 9" 235/40-17 & get contact on fender & side wall over big compressions. All the research said no interference should happen. Any advice greatly appreciated. I prefer to stay away from fender rolling.
Speedlimits are for the guidance of wise-men & the obedience of FOOLS! |
Dial in some negative camber up front. Pulls the tops of the tires in and gives you better handling to boot.
Matt - 84 Carrera |
I suggest running 8x17 Ruf wheels up front on an '87 930. The 9x17 Ruf wheels are typically used on the fronts of the earlier 930's with the front spacers removed.
The 9s stick outboard 25mm more than the 8s, They would fit fine if the early 930 21mm spacer was removed
petercory
I'm using the 10" rears w/16mm Spacers and 9" Fronts without spacers on an early 930 and they fit fine.
Bill, you are certainly the wheel Guru on here. I have read many posts from you. I am confused however. The 9' with 235/40 are supposed to work. Here is a pick of my front hub. Should the spacer be removed? Can it be removed?
Those appear to be the late 930 hubs which have a 21mm o/s built into them. The older 930 hubs have a spacer but it is used because the same 7" wheels as were used on SC//Carrera were used on the 930s '78-79 hub & removable spacer ![]() Late 930('81 up) o/s hub
Bill, thanks for the input/knowledge. Greatly appreciated. This leaves me a bit disappointed. Question, can I dial in enough neg camber with stock strut tops to make the problem go away? Or would I need to go to elephant ones & or raise front ride height? Dif size tires? UUUUGGGGHHHHHH.
Went down to a 215... Only rubbed on one side... these cars aren't perfectly symmetrical... |
The narrowest tire normally used on a 9 is a 235/
shaving the lip also provides a little more room than rolling, You can also stiffen the shocks and or springs or raise the car a tad Not all 235s measure the same, some are narrower or wider and shoulder profiles can vary too
