rallen911's Avatar
Need to identify
Hello All!
The other day, I backed my '86 Carrera out of the garage to get at some stuff stored in the corner. When I walked by where the car had been, I found a clamp laying on the ground.
It had a decent amount of oil on it, so I was pretty sure it came from the car! When I looked for where it came from, I saw the following:
It clearly came from the orange hose at the rear of the header/heat exchanger. It looks like I'm about to lose the one in the same position on the other side.
I tried looking for the part in our host's lists, but I wasn't sure what to search for. Any ideas if they are available here or can I just find something at the local hardware store?
Thanks,
Rob
- Rob
'86 911 Carrera Coupe
Old 07-08-2017, 02:04 PM
Just a regular hose clamp. 70-90 mm I believe. Host has them. If you are picky and want them to match order all four. Measure your old one to verify size before ordering.
Old 07-08-2017, 02:51 PM
rallen911's Avatar
Awesome thanks! Just to be sure the dimension you list is the diameter, correct?
- Rob
Old 07-09-2017, 08:41 AM
Yes. Hose clamps are specified by range of diameters they will work on...but...looking back at my paperwork....it's 60-80 mm range you want...check out Pelican Part HC60809-M130. Normally I wouldn't order a hose clamp but I couldn't find that size locally
Old 07-09-2017, 08:52 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Use the tear resistant type to save those hoses: NEW Genuine Volkswagen Hose Clamp (70-90mm) N0245184
'85 Carrera Targa
PCA/POC
Tags
clamp
