Functionista
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
For the $50 per rotor, it would be economically cheaper to swap out rotors. I assume your time running around dropping them off, waiting a few hours, and running around getting them back, only to have the thing last 3 moths... is false economy. My standard practice is if each rotor is less than $100, I throw them out.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
What's a few clutches and synchro's...
I took my car to the shop I have used for 30 years and they turned all four rotors for $90. My car stops just fine.
Still here
Schleprock
If you want to keep using the rotors, get one of these and see if it addresses your issue. Works very good to "scrape" the pad material off. One challenge you may encounter is the splash shield/backing plate may be in the way of doing the back side. Not to mention it's a pain in the butt to turn the rotor by hand while you're holding the hone in your drill against the rotor
Flex-Hone for Rotors, Hone Tools, Flex Hones Get one at amazon or someplace else besides direct from the manufacturer. Direct from manufacturer pricing is way more than retailers.
Kevin L '86 Carrera "Larry" |
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Soft Rotors
I found Michael Lang's post #17 very interesting where he states that the European cars use very soft rotors. My wife's '99 C230 Mercedes had the front rotors changed by the dealer with less than 10k miles, then I put two more sets of ATE rotors on before it got to 100k miles.
In 2000, my son and daughter both bought a new Saturn on the same day. When they were about a year old, I went to the local auto parts store that offered free brake pad replacement for the life of the car, and bought a set of front pads, thinking I would get a two for one deal when I had to start replacing pads. Boy was I wrong. One of the cars was totaled (with 80k miles) in the rain when my son hydroplaned off the street and hit a tree, and the other was sold with 90k miles. These cars had GREAT brakes, and to my disbelief, at about 80k miles, the front rotors had lost less than .005" thickness and just less than 50% of the pads. I never had to use the pads, and they were thrown in the trunk of the one we sold. Bob B |
Brew Master
I ended up getting the rotors turned by a local I mentioned in a previous post. $25 for the pair. Lowest cost for new that I saw was $104 for the pair. Savings: $79
The funny thing is, I had no idea I was starting such a controversial thread. Last edited by cabmandone; 08-21-2017 at 03:05 PM.. |
Schleprock
We'll just leave this right here and add some laughs/levity to the controversy
For the Fellow Brake Nerds......
gearhead
Caveman Hammer Mechanic
Even if you turn your rotors you will still need to bed the rotors. My brakes are like running into a brick wall.
Did you put a dial indicator on the rotors to check the runout? If the surface is blotchy it's a bedding issue, it's really easy to see with a flashlight. My Stoptechs have a satin sheen and to this day are uber predictable at all speeds. Add some heat into the rotor and pad and they are Velcro. The way brakes actually work is fascinating, it's not just surface friction that is doing the stopping. Hit a google search and read till your eyes bleed! New Brakes!
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 08-21-2017 at 04:29 PM.. |
Brew Master
I considered starting a "which pad" thread but I think I'm just going to wing it to avoid further controversy. Plus there's already a thread on that subject. Thanks for the input. |
83 911 Production Cab #10
Voila... rotors and pads
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Brew Master
JJ,
That's the thread I was looking at. UGH all it does it set me off on another tangent. The ATE ceramics look like they work best with the most rotors. The problem I'm having is determining which ATE pads are specifically ceramic. I checked this site and it doesn't list the composition of the pads as far as I can tell. |
When I was tracking my 951 I had the rotors turned three times before they were at minimum spec and I scrapped them. I had two sets and alternated between the two. Cost me $15 per rotor. Are you guys saying 911 rotors are made from different steel?
Doesn't look like they make it for our generation...
Give them a call you never know. https://www.amazon.com/Ate-604842-Disc-Brake-Pad/dp/compatibility-chart/B00700Y4AA
:lol: :lol:
Fat butt 911, 1987 |
The shop that turned my rotors has an on the car rotor turning machine. I had pulsating braking shudder at high speed and it is gone now. Turns out the shudder was from the rear wheels. My rotors are still within spec.
Hey while we're at it does anyone know of a good source for whale blubber? My gas lamps stopped working, but there's plenty of life left in them and I don't feel like switching to those new fangled 'lectric lights.
