A little help finding a wire please
The 3.6 wiring for the conversion is the biggest obsticle so far. That's probably because I'm electrically chalanged besides tapping into a wire to hook up a stereo.
I need a wire that is ONLY hot when the ignition is fully turned and while the starter is cranking. There's supposed to be one on the fuse panel in the luggage compartment. Can someone point one out? It's a 78SC.
Old 02-09-2003, 05:48 PM
Early_S_Man's Avatar
Porsche Crest
Paul,
There is just such a wire ... one of two Yellow ones on the SC starter solenoid, and it goes through the 14-pin connector on the relay/CDI panel!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-09-2003, 06:54 PM
If you mean the compartment in front of the driver and not the engine compartment try the yellow wire going to terminal 87 of the red fuel pump relay. The yellow wire should go into a single wire connector after it leaves the relay rubber socket or base. You may be able to "piggyback" another wire there. This is a small guage wire so I wouldn't run excessive current through it . Cheers, Jim
Old 02-09-2003, 07:06 PM
Thanks.
Old 02-09-2003, 08:03 PM
Bill Verburg's Avatar
Paul, In addition to Ingos excellent diagrams and the factory wiring diagrams, you might want to take a look at Jim Williams writeup on a 964 swap into his 78 SC. In addition Jim is a great guy. You might want to contact him for details.
As I recall only 1 or 2 pins need to be moved.
Jim Williams electric
Bill Verburg
Old 02-10-2003, 11:20 AM
Bill, thanks, I spoke to Ingo about it last night and after looking at his web site I realized that the wire colors are never going to match no matter how hard I looked. Ingo's web site cleared up what connects to what as the wires matched the two set ups exactly. I also printed out Jim's write up and it cleared up exactly what pin needs t obe moved and which connections in the front of the car need to be addresses. Your right, only one pin at the 14 pin connector needs to be moved. The remaining changes are in the engine compartment, which Jim's page makes very simple.
How's your 3.8 motor going?
Old 02-10-2003, 04:11 PM
Case is done we're waiting on the heads. Weather up here has not helped.
I was very impressed by Ingo's write up, It's the best I've seen. Can you amplify on the color discrepancies that you have found.
I was also thinking of posting some diagrams of the position and routing of the stock harnesses over the years that I have. Don't know if that would be helpful but maybe i'll try to scan them tomorrrow.
Bill Verburg
Old 02-10-2003, 04:17 PM
Bill Ingo's color description is right on for my 93 964 wire harness at the motor:
The 74 14 pin connector is different as shown by Ingo:
My 78 reads as follows:
1. Yellow
2. Green
3. Blue
4. Green/Red
5. Green/White
6. Grey Brown
7. Blue/Yellow
8. Brown/White
9. Green/Yellow
10. Red/White
11. Blue
12. Black/Violet
13. Yellow/Black
14. Red
The differences between the 964 (at motor) and 78SC (at chasis) are as follows:
2. SC=Green, 964 empty
3. SC = Blue, 964 = Yellow/Black
5. SC = Green/White, 964= Green Yellow
7. SC= Blue/Yellow, 964 = Blue Green
8. SC=Brown/White, 964=Brown/Blue
9. SC=Green/Yellow, 964 = Green/White
10. SC=Red/WHite, 964 = Red
13. SC=Yellow/Black, 964=Yellow Green
14. SC=Red, 964=empty
If anyone knows what the corresponding colors are that would be great. Once I figure it out I'll see if Ingo will do a graph.
Old 02-10-2003, 07:44 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Re: A little help finding a wire please
Paul,
I am still wondering why you would need a signal that is hot when the starter is cranking for the conversion. After reading Jim's explanations I was under the impression that you only need the ignition signal (15) and permanent power (30) to the DME harness. The DME will do the rest: Once it realizes flywheel movement via the pickup (cranking) it'll turn on the fuel pump via the DME relay.
As I understand signal (15) is hot whenever the key is in the "run" position. It switches on one side of the DME relay and powers the ignitors and the injectors.
The second circuit of the DME relay controls the fuel pump. The pump only runs while flywheel rotation is sensed. It's a safety feature. On older cars the fuel pump runs once the key is in the "run" position. On my 74 there isn't even a relay for the fuel pump.
Am I missing something?
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 02-10-2003, 07:58 PM
