Certified User
billjam's Avatar
Width of Turbo flares vs Carrera
What is the difference in width between Turbo flares and Carrera flares?
I spent an hour or so searching threads last night looking for this info. Found lots of interesting stuff and read about lots interesting builds, but all I really want to know is how much wider are Turbo flares compared to Carrera flares (front and rear)?
On my 88 Carrera, the width inside the front wheel arch is 355mm (measured from the top of the wheel arch opening to the body just behind the strut) and the rear is 305mm (measured horizontally from the top of the wheel arch opening to the body) give or take a couple of mil.
If someone with a Turbo can take the same measurements from the top of the wheel arches in to the body, it will give me what I need.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 01-22-2018, 04:08 AM
Certified User
billjam's Avatar
OK, here's some more information ...
I am looking at different wheel options for my Carrera with and without Turbo flares. I have a set of steel Turbo panels in the attic and can't decide whether to jump in and fit them. Finding some nice wide wheels will tip me over the edge!
I have drawn the basic layout of the wheel wells and this allows me to play with different combinations of wheel size and spacer width.
Bill
2024 Macan S
Old 01-22-2018, 05:21 PM
911bruce's Avatar
What offset are you using on those wheels? I did not realize we could fit 9" rims in the rear of the SC.
Old 01-22-2018, 08:05 PM
FstTarga's Avatar
16x9+15 Fuchs fit without rolling the fenders on my Carrera, flares are the same
Old 01-22-2018, 08:34 PM
Certified User
billjam's Avatar
Bruce, it is on the drawing ... ET 17.
This offset gives about 10mm clearance on the swing arm bolts.
The outside of the tire is about 15mm inside the wheel arch at the top. This is with 255/40R17 Goodyear Eagle F1 tires that are 265mm wide overall.
I have another set of wheels with same size Kumho Ecstas but those tires are only 255mm wide overall. They have more square sidewalls, so they fit with more clearance.
Bill
2024 Macan S
Old 01-22-2018, 09:00 PM
MARISOL78sc's Avatar
16x7 16x9 Turbo fitment on my SC
Paul
2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951
1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold
Instagram: @rennsport98
Old 01-22-2018, 09:07 PM
Certified User
billjam's Avatar
Bump ... still looking for that dimension!
Bill
2024 Macan S
Old 01-23-2018, 04:12 AM
faverymi's Avatar
Turbo flares are 2 inch wider than carrera.
That being said from my desk and not measuring tape you have to add around 50mm to your measurements . (cars are stored for the winter)
It's well known that carrera rear flares are 9" and turbo are 11"
fronts are 7" and turbo 9" in the front
Hope it helps
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 01-23-2018, 05:08 AM
Chain fence eating turbo
Bill, sub'd.
I run 285mm tires on my 87, and virtually no rubbing. One major caveat though, I have both torsion bars and helper coilovers. My rear is very stiff.
Only time I'll get a little rub sound is on a major, and I mean, really big bump at high speeds**.
Curious, are your turbo flares steel or glass?
**I take that back, after moving the small spacers I had from the front to the back, it no longer rubs no matter what....
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-23-2018, 05:25 AM
Certified User
billjam's Avatar
I had kinda guessed the difference was around 2". I have Turbo panels, but there aren't any reference points that can be easily measured for comparison when they aren't on the car.
Tippy, panels are all steel except for tail of course. What is your wheel and tire size on the rear? ET? It sounds like a good alternative to doing a whole body kit!
Bill
2024 Macan S
Old 01-23-2018, 05:39 AM
Bill Verburg's Avatar
just going by the official Porsche specs for width of an '86 Carrera compared to a T/L or 930
width
Carrera 1652mm
T/L or 930 1775mm
difference is 123mm at the rear fender
here's what i've found to be at or at least very close to the limits of an SC/Carrera wheel well
here are the specs for the widest wheel/tires I've been avb;le to fit w/ a lot of work and some compromise on ride height, on the left is a typical 16" Hi perf Fuchs setup on the right maxed
Bill Verburg
Old 01-23-2018, 05:51 AM
I have Tramont 10.5". Not sure offset. I'd have to look after work.
Bill, here's a vid of how little mine squats in the back. A sticky drag strip, fresh Sumitomo 285's, launching at about 3500 to 4000 RPM, and dumping the clutch.
Old 01-23-2018, 06:03 AM
