scumbag
i get so excited when you update this thread. i love this build.
R lights because of the weight? functionality? or aesthetic?
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
Doing the same lights for mine.
I like the idea of LED units instead of the old Hella’s Where did you get the light units?
Swapped my WRX Sti MY02 for a Porsche 911SC '83 Keep buying parts to make it look older. Mid life crisis is now in its 12th year. |
The lights actually came on the car. I decided to keep them as it fitted in with the weight reduction mission, and they have grown on me and now I’m “sort of” continuing the R theme with the front. Got some covers to replace the front light assemblies (removed more weight) and gets a functional brake vent hole similar to the 911R front end...
77’ 911 Karminrot Build Thread: http://forums.pelicanparts.com/porsche-911-technical-forum/985164-project-77-new-build.html |
scumbag
as you approach completion, what do you think race weight will be?
Took some more weight out with 935 front suspension, poly windscreen and wheels.
Put some more back in with extra roll cage bars for chassis stiffness and safety, and some rear suspensions mods and bracing. Expect wet with driver and maybe some driver cooling gear around 2400lbs (Or less....)
scumbag
Fitting the front signal cover / vent.
I had some blanks but they were only half the length covering the indicator void, and I then still needed to buy the horn grille cover, or make up some mesh grille. So found these, and like all fibreglass parts required some cutting and modification! It’s really never ending.... but I keep reminding myself, be patient, just do it once the way you want it now, and will be better than changing it later.
77’ 911 Karminrot Build Thread: http://forums.pelicanparts.com/porsche-911-technical-forum/985164-project-77-new-build.html Last edited by DHE11; 06-21-2018 at 02:06 PM.. |
Some of the larger body parts now fitted...
While a little harsh on the eyes in full sun, pleased to see the lines of the car still show up, and are not totally dominated by the colour. ![]()
Looks good!!! Glad to see the updates and that it's coming along together quite nicely! Did you get the wing all figured out already too?
23 Macan GTS 97 240SX 94 Land Cruiser Too many Miata's to count. |
Yes, after doing research and comparisons, decided to go with with APR wing pictured below. Spec’d the attach spacing so ill be able to run on my new GT3 style duck tail, or the RS3.8 tailbase. APR are making the wing now, and I plan meet KC and pick up early July ![]() Will do my own testing, but expect the GT3 style duck tail to be the go to set up on the high speed circuits with lower drag penalty. Looking forward to getting back to Bathurst and our new track at Tailem Bend to test....
Hey mate
Forgot to tell you I’m in the US at the moment I’ll get that booster back in a couple weeks... Man that car is PINK!!! 😎 |
Awesome news! Does this mean you're going to be running two different sets of uprights, and at different heights?
Let me know when you figure out the dates you'll be out here again, I'll make plans to meet up with you!
Yes Eric,
Two tailbases and two sets of uprights. Have run a widebody with RS3.8 tail on the previous car with a much smaller wing element. The challenge on this car will be balancing the front with more rear aero. For low speed events like club motorkhana's I can remove wing entirety and just run the duck tail.
Yes Eric,
Yeah, it's pretty bright... (You'll be able to come see it in person in a few months...)
Some boxes arrived this week!!!
New wheels... Light and wide @ 15-17lbs for 17"s ![]() Thanks to Ryan @ Jongbloed who made a very light set of wheels for me. Was a bit of planning involved, and by knowing more about the car, its weight and how it was going to be used, we could optimize a wheel that would be super light, but importantly still be strong and reliable on track. Ended up going with an aero series wheel with a smaller centre and stepped barrel which helped keep the weight down and saves well over 12lbs of rotating mass for the set. The front and rear look a different colour in the photo below, but it's just reflection, they are both anodised black (paint's too heavy)
Those wheels are HOT !!!
Knowing I was chasing weight, Jongbloed built the wheels with all titanium hardware... saved nearly a pound per wheel replacing the standard ARP fasteners!
Wow thats a bold colour, cant wait to see if finished and those wheels are awesome!
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
scumbag
this is the kind of stuff that makes my day to read. attention to detail and commitment to excellence.
