Air always run through the exchangers to heater boxes and the cable from the cabin moves a set of vanes that either sends the hot air up to the cabin or sends it out into the airstream under the car.
Rutager West 1977 911S Targa Chocolate Brown |
That sounds right. I remember the valve to the cabin, but forgot the valve that opens beneath the engine.
Thanks. Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Hilbilly Deluxe
Take a look at the tech article on flapper boxes, it show where they are. https://www.pelicanparts.com/techarticles/tom_sharpes/heater_box1.htm One thing to be aware of, without the blower, the airflow through the heater is dependent on the speed of the engine fan, and therefore engine RPM. If you are sitting at a red light at idle, there isn't much heat. |
Vintage Owner
That’s why we have a gas pedal and lower gears while driving! I never had any complaints with the early style heat exchangers in my 911s or 914-6s. Perhaps defrosting is a bit slower, but once you understand how the system functions, it’s completely logical.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Coram Deo
The flapper valve closes off air going into the car, and at the same time opens below the car so that the hot air from the exhaust manifold is vented there.
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
Edit. Oops, already answered several times above!
www.classicretrofit.com Last edited by Jonny H; 02-09-2018 at 02:35 PM.. |
Hilbilly Deluxe
Sitting still for any length of time, you really need to increase the engine RPM to get any significant airflow through the heater. Never really bothered me, but it doesn't change the fact it happens. |
I have a targa not a sunroof car, but are you sure you even need to open the sunroof to get air pressure differential? The vents above the rear window (or on the roll bar in a targa) do that by design.
Undocumented User
![]() This should motivate you. |
Tidying up........
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
OH MY GAWD that is a thing of beauty.
