engine removal
Anyone have an idea the lift height needed for the jack or jacking method to go under the engine to remove once rear of car(911) is lifter. Looking at a motorcycle lift with 17 inch lift height. Thanks Jerry
Hi What year is your 911?
When you want to remove the engine all you need the floor jack..To make it easy for you remove the rear bumper .Which is 10 bolts and screws. 4 nuts on side harmonicas rubbers, 2 phillips screws on bumber rubber strip, 4 bumper to bumper shock nuts.Remove the license plate lights...and you are ready to go..Some 911 have heat shield protective plate ... i use this one and with it there is plenty clearance to pull the engine out. ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 03-17-2018 at 12:56 PM.. |
Fleabit peanut monkey
I am thinking that would be ok. Get the front wheels off the ground a foot or so. That will decrease the decline towards the front.
Have a floor jack for backup. Two if you can swing it. Here is a pic without the front elevated. (stolen from a pelican post)
1981 911SC Targa Last edited by Bob Kontak; 03-17-2018 at 12:53 PM.. |
lifted on jack stands but not real high. That's the Craftsman motor cycle lift, it's a really great unit, not as cheap as the HF one but you get what you pay for! Note that the rear 6 ton jack stands are INBOARD on the torsion bar tubes, gets stuff out of the way. ![]()
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 03-17-2018 at 01:39 PM.. |
There was a post a while back talking about jacking up the rear to drop the motor out. If I remember correctly, the rear torsion bar covers needed to be about 24in off the ground for enough clearance. This is with the rear bumper removed. I don't remember what the number was with it still on.
Jonathan '79 Copper 911 SC '88 White 911 Carrera- 98mm p/c with JE 8:1, Turbkraft EFI-T cam, Carrillo rods, Injector Dynamics 1050x, twin COP, AEM Infinity, twin Garrett GT2860rs's |
Just went and measured mine with bumper on is up at 28”. Engine is much taller than 11”, so the 17” jack height will do the job easily.
You can also start engine out and raise the car up to the final height.
Rutager West 1977 911S Targa Chocolate Brown |
Yep, motorcycle jack works for engine drop - - and agree with all the above tips too . . .
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
I use an ATV jack stand - more stability. Works great. I need 875mm (34.5") clearance to get my SC engine out.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Thanks for all the info. Last time I took the motor out in the early 90's I had a shop with a rolling trolley on a beam with a large hoist. We lifted the rear with that.
Just perspective due to the angle.
1981 911SC Targa |
Hope all is well stay warm. |
Dave, thanks, the benefit was beyond my expectations. Ihave to continue moving forward with my life as long as my health allows. If I sit here and watch tv all day and dwell on the negitives is nott mentally healthy. I glad I have my 911 to keep my mind off the bad stuff!
I understand, Television will melt your brain! If you need any help/tools et let me know and Bob can swing by. Hopefully the weather will turn soon that would be a big help. I'll pm you my email and phone # if you need something give me a shout. Take care
