3.2 Stutter During Hard Acceleration?
New and interesting problem. Within the last year or so, I've developed an issue. Occasionally, and that's the frustrating part, when I'm accelerating, the engine will simply cut out around 2500 or 3k, gear-independent. It basically pauses for a minute, with the gas pedal doing nothing, and then it will catch again and I can continue up through the power band. I haven't been able to repeat it at will, and it's an odd sensation, so I'm unable to give any more specific feedback.
Engine is a 3.2 bumped to 3.4, single plug, relatively new distributor and wires, Steve Wong chip put in about 2006. Car is at Rudtner's as we speak for unrelated issues, but I did ask him to look at the AFM arm issue that's popped up. He's replacing plugs and fluids, doing normal 15k service stuff. That may solve the issue without focusing on it. Any other possibilities or areas of focus? Thanks.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Counterclockwise?
How does it run in the rain?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Had a similar issue on my '84. Thought it was a bad DME relay but turned out to be a clogged fuel filter.
2000 Boxster S and 2016 Audi A6 |
I would rather be driving
This could be due to worn carbon traces on the AFM resistor board. There are ways to reclock the AFM wiper arm and provide a fresh surface. This requires AFM disassembly.
The rpm band you describe is where most engines spend their time cruising. This is what wears the track.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
One thing to look at is the inside of the ignition coil tower where the coil wire plugs in.
Even though you have new wires, this visual coil inspection may have been overlooked. The coil is mounted up high with a plastic cover over it, so it is one of those areas that is not easily seen without a mirror or taking the coil off its mount.. I have seen a few with the typical green/white corrosion that was so bad I was surprised it ran at all, but caused occasional throttle response issues. |
I had some of the same issues mine was a combination of clogged fuel filter, bad negative battery cable and my flywheel sensors were shot.
I'll ask Bill to look at all of this. Can't hurt.
Appreciate the thoughts.
Chain fence eating turbo
I had the same problem and never resolved.
My last logical thought was my alternator had went out (brushes too worn), and the DME really doesn't like lower voltage.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Most of the above has been addressed by the 15k service bill did. The afm track is an interesting possibility. If the problem persists I'll try that next. Will report back in any case. |
I pulled out the DME and put in MegaSquirt II.
crank position sensors.
My car did that. It was the coil. Replaced with the old stock black OEM coil, problem solved.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
^^^ Let the shotgun diagnostics begin!!
Fleabit peanut monkey
Bwa Ha Ha Ha.
Do the night time check of your engine bay for the potential light show. Rev it up once your eyes adjust to the darkness. The stutter is what triggers this for me. My coil secondary would arc to one of the primary posts only on hard accel which also presented itself when I would blip engine when testing. Your symptoms don't quite sound the same as mine as it was a huge sensation of deceleration, I would lock the seatbelts from lurching forward. You could see it in the daytime but I suggest the night time check to just put that variable to bed. How's that for shotgun?
1981 911SC Targa Last edited by Bob Kontak; 03-27-2018 at 02:09 PM.. |
Had a similar issue and it was a loose connection on the starter and was creating an intermittently bad ground.
Starting off 4-10 there, Bob!
I got up to 12 gauge..... ![]()
I am very much against it and prefer to do as much testing as possible before spending $$. sometimes there are fixes that educated guesses based on symptoms and prior experience.
Cheers, Joe |
Customer brings in his 2003 Lincoln Navigator which I have a professional scanner for. Traction control is trying to engage but cant. Grindy noise in left front wheel where advance traction is trying but can't. One "real" ABS code. Voltage out of range. Battery on the ragged edge. Bus link/CAN communication errors in three different modules. 4x4 module wont communicate with scanner at all. Clear all codes and car does well until it rains. After a day of fiddling customer says "When it rains, I get water all over the floor on the driver's side." Just kill me. Thanks for that tidbit. Ford wants about $2500 for that fix. Couple of modules/fuse box and entire under dash harness replacement along with windshield. Assuming that is the problem.
1981 911SC Targa Last edited by Bob Kontak; 03-30-2018 at 02:06 PM.. |
