Tach/Odometer Connection?
1986 Carrera 3.2. I pulled my non working tach and sent it out for repair (it is not back yet). Just noticed my odometer is not working. Speedometer is fine. Before I complicate it for myself (my usual approach) is there a connection between the removal of the tach and the odometer not working?
Old 04-02-2018, 01:15 PM
Probably a broken gear in the odometer. Same signal drives both the speedo and the odo.
Old 04-02-2018, 06:47 PM
Thanks for the reply. Too clarify, if the speedometer works and the odometer does not then the problem is the plastic gear inside the odometer. The failure of the odometer has nothing to do with the tach?
Old 04-02-2018, 08:52 PM
That's right, nothing to do with the tach. The odo gear is a common failure point.
Old 04-03-2018, 04:43 AM
Thanks for your input. Much appreciated.
Old 04-03-2018, 05:41 PM
porschetub's Avatar
They normally fail due to old age,but if someone attempts to reset the meter while the car is moving that causes a failure also.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 04-03-2018, 10:42 PM
