Uncertifiable!!!
I feel your pain but unfortunately have no suggestions. Following hoping for a solution.
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
I would check all of your grounds:
Battery neg to chassis Behind fuel filter Intake runner i think 2 others in the frunk Transmission ground strap Only happening at operating temps sound like heat expansion - could also be ecu internals related?
Shirish 1987 Carrera, Granite Green |
What is the syndrome called when a car won't restart while warm?
Owner has to let it cool down and then it starts fine? Heat soak? What is that?
1986 Bosch Icon Wipers coupe. |
Chain fence eating turbo
Sounds like you are overheating a component in the DME. I'd send the ECU to Ingo
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Irrationally exuberant
My personal list of what I would suspect when a 3.2 suddenly dies when hot but runs fine otherwise:
- DME relay - Speed and reference sensors - Head temp sensor esp. if original 2 wire type. - DME Since you've replaced the 1st 3, I'd suspect the DME at this point. Swap DME's with a friend. the idle speed changed over the model years but for testing purposes, you should be fine. Note: If you have a black ignition coil, keep it unless you know it is bad. Replacing it with a newer silver coil "while you're in there" is a downgrade in reliability in my opinion.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Just an update - and an opportunity to thank all those who have chimed in with experiential suggestions - I am in midst of cleaning all ground connections while waiting for new plug wires...If the problem persists, its time for a DME check up...Who is Ingo, where can I find him? Sounds like he's the place to go...Thanks again you all, immensely...
ischmitz on the forum, he helped me a ton with a DME issue and a very nice guy.
Subject matter expert Ingo Schmitz I'll PM him for you, Scott
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Here you go:
ischmitz ischmitz is offline Registered User ischmitz's Avatar Join Date: May 2002 Location: Santa Barbara, CA Posts: 4,465 Garage Send a message via Skype™ to ischmitz
I had a mysterious engine misfire, and was stumped. I finally looked at the coil itself. It was oozing black goo. The real pain is no one really sells a new perfect replacement coil for the 3.2. The Porsche dealer will sell you a new coil in a Porsche box that is a total waste of money, Bosch branded coil made in Brazil. Those are oven NFG right from the box. The aftermarket coils are all the wrong voltages.
I finally located a OEM Bosch black coil from a junkyard. It has been perfect. Check your plug wires, especially the coil wire, and the coil. And get a solid state DME relay sold by on of the members of the board.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Update: Cleaned ALL grounds, changed out plug wires with new set. Initial reaction was positive, car felt zippy and tight. Upon reaching temp, she burped a bit just to warn me she was about to cut out...And she did. I sat for 30 seconds, fired her up and she got me back around the corner where I started - and died upon applying the parking brake. I know all about the silver coil from brazil, er I mean Bosch...TWICE before! I am not ruling out heat soak of the coil, which occurred before with my 930...Not knowing squat about the DME I will get it ready to send to Ingo...
As soon as I figure how to post pics, I have some "where does this wire go" questions for the group. Thanks again all. |
I would also double check the resistance of the CHT sensor you fitted - appreciate its new but Bosch (?) quality hasn’t been the best for a while, I had a brand new one changed out within 50-100 miles a few years ago.
In fact I believe there is a way of jumping the CHT, to remove it from the ECU circuit, purely for testing. |
Just because you replaced the Crank Positions Sensors with new doesn't mean that a new part is not faulty. A new part can and will be faulty out of the box...
There are a couple of solder joints in the DME that you could check for yourself if you can solder. I would check the fuse and fuse connections to the fuel pump. In my case there was a bad connection to the hot wire to the fuel pump that was intermittent when run more than 30 minutes.
I could not fix the problem until it failed completely. It's hard to diagnose a problem if it is working when you are testing it. I traced a lot of wires, checked harness continuity, cleaned a lot of grounds and tested and retested. I did send the DME out, and it was worth it just to eliminate that as the problem. I had a bad AFM on another car. It would cut out, but only at specific RPMs where the resistor strip was worn out. It was worth it to me to work on it myself. How is a mechanic going to diagnose it any better if it doesn't fail while he is working on it ? |
But less likely, and the symptom would most likely be total failure, does not run. It seems like something is getting hot and failing under hot load.
I had this happen with crank sensors. Failed when hot, then cooled then OK. Replaced with new Bosch (now made in the Peoples' Republic of China) - failed soon after. Finally got a good one in there...
PRO Motorsports
Sure sounds like cracking solder joints on the DME circuit board.
One other thing I’ve seen is a tachometer that would heat up and short out the primary ignition circuit. Try unplugging the tach next time it dies, just go rule it out. |
Eng-o-neer
This probably isn't your issue, but in the interest of providing more options than none...I had a similar issue, and it turned out to be the ignition module overheating due to a lack of heat sink. This was on a 3.6, though:
What's that smell? Wait, and why isn't my car running?! It looks like the 3.2 ignition module is built into the heat sink, but maybe the internal connection isn't great anymore, or the engine bay is getting too hot now...I dunno. |
86 3.2 here...had similar issues a few years back. Wasn't DME relay...wasn't grounds...wasn't wires or the coil. It turned out to be a bad solder joint in the DME that allowed it to run fine untill the unit heated/expanded. I took out and had to look twice before I found the crack. I re-flowed the solder and all has been good for years now.
1986 3.2 Carrera Last edited by ben parrish; 05-20-2018 at 01:42 AM.. |
Ok this is an easy one. Only because it’s happened to me with customer cars a few times.’ You have done all of the right things so far but I am seeing this more often. Open the rear deck. Look to the drivers side where the three sensors on the rail plug into the main harness. As the main harness makes a 90* turn under the outer shielding is where you will probably find cracking on the crank sensor wiring. Most but not all, I have found all three cracked. This problem will only get worse till it won’t run at all. That’s when they usually get towed in.
67 Normale "Old Rusty" 67 Rennen inspired 73 ST Caged Beast RGruppe #383 |
