Exclamation Removable Backpad to Access Engine
If you've been visiting all914.com, this issue is a rerun. But check out my removable backpad project, completed last weekend.
Old 03-11-2003, 07:24 PM
Great idea, I would have had the upholstery shop fill the hole in the top pad.
CCLinLOO
Craig C. Laughlin CAMP 914
Helping to bring your 914 into the 21st century.
http://www.camp914.com
Old 03-13-2003, 08:00 AM
Biggy72's Avatar
ya what's that hole for any way?
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 03-13-2003, 03:34 PM
A VW dome lite. worthless.
CCLinLOO
Old 03-13-2003, 03:43 PM
RETIRED
Joe Bob's Avatar
Well, if ya got a six....the easiest way to change the alternator belt.
2012 ML350 3.0 Turbo Diesel
Old 03-13-2003, 04:06 PM
That hole??
CCLinLOO
Old 03-13-2003, 04:41 PM
Biggy72's Avatar
so that's where the dome light is....I've been tryin to figure out where the dome light went but my car doesn't have one. I'll probably put it somewhere a little better than right there though.
Black 72 1.7 914
WSU Formula SAE
Old 03-13-2003, 05:03 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
To change a fan belt thru the dome light you would have to be a gynocologist, Craig.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 03-13-2003, 05:22 PM
mikester's Avatar
Send a message via AIM to mikester
my dome light works great.
Damn well better too, took me the better part of an afternoon to get it rewired to the doors.
-The Mikester
I heart Boobies
Old 03-13-2003, 10:04 PM
Just to clarify, the little hole in the leather in the first picture is for the dome light. The large hole, (reproduced below), sealed by an aluminum panel, lined with screws, is how you access the engine compartment to change the fan belt and to manually crank the engine, using the alternator nut in order to perform a valve adjustment.
The reason why valve adjustments are such a pain in the ass in 914s is largely because its a ***** to turn the engine over manually (because the alternator pulley/crank pulley is hidden against the firewall. That's why people sometimes chip the fan trying to turn the alternator/crank pulley and that's why PP has recommended that you jack the car up and turn one of the tires while in gear. All of this is to get around the problem of hand turning the engine.
Douglas
Old 03-14-2003, 01:11 PM
canna change law physics
red-beard's Avatar
Geoff
ROFL-AL-AL-AL!
James
James
Red-beard for President, 2020
Old 03-14-2003, 01:32 PM
Andyrew's Avatar
Speeking of that....
A gynecologist had a burning desire to change careers and become a
mechanic. So he found out from the local tech college what was
involved, signed up for evening classes, attended diligently, and
learned all he could.
When the time for the practical exam approached, the Gynecologist
prepared carefully for weeks, and completed the exam with tremendous
skill.
When the results came back, he was surprised to find that he had
obtained a mark of 150%. Fearing an error, he called the instructor
and said, "I don't want to appear ungrateful for such an outstanding
result, but I wondered if there had been an error which needed
adjusting."
The instructor said, "During the exam, you took the engine apart
perfectly, which was worth 50% of the total mark. You put the engine
back together again perfectly, which is also worth 50% of the mark. I
gave you an extra 50% because you did all of it through the muffler.
Old 03-14-2003, 04:14 PM
skline's Avatar
Ok, So you cut a hole in your firewall to do valve adjustments easier? I made a T out of a 2X4 and a 4X4 to hold one of the wheels while I turned the other one to rotate the enigne. It fits perfect between two lug bolts to hold one wheel while it is up in the air. With the marks on the flywheel I can see underneath throught the small hole in the case. Do a complete valve adjustment in about 15 minutes alone. Works great.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 03-14-2003, 04:26 PM
The wooden stilt idea sounds interesting but I'm having a hard time picturing it. Love to see photos.
Douglas
Old 03-14-2003, 05:42 PM
skline's Avatar
2 nails, 1 2X4 about 2.5 feet long, and one 4X4 about 2.5 feet long. Took 2 minutes to build and works great. I feel safer with the car on Jack Stands rather than taking the chance of rolling over or off a ramp.
75 Slantnose V8
72 914 Parts car
Old 03-14-2003, 07:05 PM
D7N7MASTER's Avatar
All creative ideas... How 'bout one car ramp & one jack stand?
www.pelicanparts.com/gallery/d7n7master
Old 03-15-2003, 06:32 AM
D7N7MASTER's Avatar
The REAL reason why valve adjustments are such a pain in the ass in 914s is largely because its a ***** to get your hand/hands inside the tin to reach the adjuster. I cut the **** out of my arms every-time. Am I tryin' 2 hard?
G
Old 03-15-2003, 06:38 AM
914 Geek
I only put one side of the car in the air at a time.
I get to most of the valves from the rear of the rocker box area, with my arm laying on the heat exchanger. A couple I can get to from the front of the rocker box. And on one side, I can get to one or two valves directly from the side, sort of.
--DD
Old 03-15-2003, 09:13 AM
Mountain914's Avatar
hey Douglas, I like it!
Here's some pics of mine. I haven't yet put a metal panel in, I have been flip-flopping between aluminum and stainless.
Makes distributor work, belt change, etc... much easier!
Lee Jacobs
1972 914 3.0L, 2004 VW R32, 1996 Dakota
members.rennlist.com/mountain914
Big Aspirations, Small Wallet
Old 03-15-2003, 10:14 AM
M. Hendrix's Avatar
ROFL! Thanks man, I needed that.
People with A/C could probably benefit from the extra cooling of just leaving it open, the extra heat in the winter is also a plus.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 03-15-2003, 12:16 PM
