Dbelleperc's Avatar
Some more problems
Well here we go again. The problem is when I make a right turn the engine doesn't seem to have any power and the car gives off a slight backfire and it jerks A LOT and I just want to put my head between my legs and pull off the road. On left turns it doesn't happen as much but it does. Pulling away from a stop it jerks and backfires but it also does not jerk or backfire sometimes. So is this a "CHECK YOUR GROUNDS" situation and if it is which grounds should I check. Or is this some other problem.
70' Porsche 914
73' Porsche 914
03' Mini Cooper S
03' Volkswagen Passat GLX B5.5 4-Motion
Benjamin Miles Keaton (ben, lj) - RIP June 2nd, 2005
Old 04-14-2003, 02:48 PM
Sounds more like a timing issue, but with 914's, always check and clean all your grounds. I doubt if turning right or left is causing the problem.
Tranny ground strap
Grounds to body behind battery and relay board
Grounds in headlight buckets
Are you running D-Jet or carbs? Could make a difference there. Hopefully some of the guys running carbs can shed some light. (If you have them.)
When was your last good tune-up?
When did you change your fuel filter last?
Just a few places to start.
Don
Don Kiepert
'73 Big Bore
'02 GTI 1.8T
Race a Porsche - There's more to life than left turns!
Old 04-15-2003, 06:16 AM
914 Geek
Wiggle all the wires in the engine bay with the engine idling. Carefully check any that make a difference--they may be breaking or mot plugged in well.
Grounds for the 914 engine are at the rear of the crankcase seam, up on top of the motor. There is another ground point under the relay board, down low on the firewall.
--DD
Old 04-15-2003, 08:40 AM
That's right, thanks Dave, the FI ground connectins are clustered under the intake runner for the #3 cylinder. Look for a triple spade connector with nothing but white wires going to it.
Don Kiepert
'73 Big Bore
'02 GTI 1.8T
Old 04-15-2003, 03:03 PM
Dbelleperc's Avatar
I am running D-Jet and I have checked the grounds at the #3 cylinder but I will check all the other grounds tonight. I'll get back on the progress. Thanks for the help. And yes turning right or left does make a difference because everything will be normal and on a slight right turn the car will start to lose power and bog down. And I had my fuel filter changed about 1000 miles ago.
70' Porsche 914
73' Porsche 914
03' Mini Cooper S
Old 04-15-2003, 06:29 PM
Jim Smolka's Avatar
Check the wiring around the steering wheel column.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 04-15-2003, 06:38 PM
