cylinder head smog injector problem
we have a 912 e with a stripped smog injector. Does anyone have a simple (okay- patch job- the client can't afford to take the heads off) solution? The threads are really down in there and the oe air injector just spins around in the hole now
Thanks! |
Air pressurize cylinder with piston at tdc (both valves closed). Drill for helicoil (air pressure will blow cuttings back in your face) - use heavy grease on tap to capture "shards". Aluminum shavings will probably vaporize at combustion temps anyway (1400-1600 degrees).
OR JB Weld it in.
"Inventor - Blue Flame 914 Seat Heater" "Yellow Rusty Cars Are Faster" _____________________________ '70 2.5 (I'll never finish it - Somewhere over the rainbow.....,) '73 2.0 (Just Not The Same) '74 2.0 (Heartless & Lungless) |
we'll see if we can get a tap in there- long ways under the sheetmetal
thanks |
TRE Cup,
That sounds like John's car (silver-blue E). Ron, That is what I like about the board, smart folks giving great advice...
Thanks Coldbass (ale - mmmmmmmmmmm)
Not smart, just years of fixing broken race cars at the track in the heat and dirt.
The car is a black E with electric windows, tan full leather, Carrera front suspension, polished 7 x15 fuchs all around, H4 euros, fogs, sunroof, dual power mirrors- yep some mods came to her over the years!
The JB weld has set in over the long weekend, and so far so good thanks again db |
