grind weld build
sean_V8_914's Avatar
Got sway bar?
does anyone have a stock sway bar laying around that they want to sell cheap?
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 11-09-2003, 08:40 AM
grind weld build
thanks Herb!
73 Orange, CS #601
Trek 6500+
Sean M!
Old 11-09-2003, 08:46 AM
skline's Avatar
Hey Sean, are you trying to tip it over? I may have one here, you looking for front or rear? Come up and visit sometime and we will look throught the garage.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 11-09-2003, 08:57 AM
skline's Avatar
Maybe you just need a little more weight in the front a back, I have some bumpers from a 76 that can add that extra weight and for you I will sell them really cheap.
75 Slantnose V8
72 914 Parts car
Old 11-09-2003, 09:00 AM
canna change law physics
red-beard's Avatar
Kenny Powell might have another one...
James
Red-beard for President, 2020
Old 11-09-2003, 12:20 PM
Have you tried Atkins?
Old 11-09-2003, 04:51 PM
handyher's Avatar
Send a message via AIM to handyher Send a message via Yahoo to handyher
I have a front one 19 mm will bring with about nove 20 when i drive out your way.
renee
71 914
65 fstbk mustang
97 "burb"
94 pic um up
Old 11-09-2003, 08:38 PM
Front or Rear?????????
If Rear, do you have the mounts????????
Ken
Anything worth doing is worth doing in excess
Every silver lining has a cloud
Assume Nothing
Old 11-10-2003, 08:06 AM
Mine leans like that too. Reminds me of when I drove tour buses in college. I installed an original (15mm) bar but haven't installed the drop links and U-brackets yet; I'm hoping that even the modest size OEM bar will help a lot.
2005 BMW 530i
2008 GMC Acadia
Old 11-10-2003, 09:37 AM
HMeeder's Avatar
Porsche Crest
Not sure if I'm in favor of Sean improving his car. He ran well for his first AX and would be driving against me. Though competition is really what makes me drive harder. Some tweaking of his car's set-up and he would be dangerous!
Watching him, though, I did fear for him scraping his door handles. My recommendations: Heavier springs in the rear, sway bar up front and some softer compound 205/15s. That would be the starting point. He's got springs at home (put them on now!)
Herb
'72 Tangerine 'Teen
2.4 liter aluminum handgrenade
Old 11-10-2003, 10:51 AM
handyher's Avatar
front sway bar have all but the u things that hold it to the car in the front trunk area. had to cut them but have stuff that bolts to arms and still have bushings for where the u things go.
renee
71 914
65 fstbk mustang
97 "burb"
94 pic um up
Old 11-10-2003, 11:23 AM
914 Geek
The mounting plates are available from the board's host.
DO NOT USE the "no gas tank removal required" kit. It's junk, and your fenders will tear out in months (or maybe years).
A stock front sway bar, all on its own, will help. It's also a good match for stock rear springs and for the aftermarket 100 lb/in "almost stock" springs. To control the body roll even more, a larger front bar and stiffer rear springs will work quite well.
--DD
Old 11-10-2003, 11:33 AM
handyher's Avatar
that is why we had to cut the brackets because i did not want tank out gas tank!
renee
71 914
65 fstbk mustang
97 "burb"
94 pic um up
Old 11-10-2003, 02:02 PM
Unregistered
sammyg2's Avatar
I don't have a spare sway bar but I have some old casters we can bolt to your door handles
A stock front sway bar with stock (good) rear springs is a very good combination, an aftermarket adjustable front and 140# springs is a great upgrade.
RTFRB
Old 11-10-2003, 03:28 PM
RETIRED
Joe Bob's Avatar
AX....MOST run just a front sway bar. No rear unless you have an LSD. Sway bars, t-bars, springs need to be put in with each other....bigger T-bars, you need to adjust the rear springs as well...Big sway-bar up front etc.....
2012 ML350 3.0 Turbo Diesel
Old 11-10-2003, 06:57 PM
skline's Avatar
Nice avatar Mike, I love to watch the jiggle.
75 Slantnose V8
72 914 Parts car
Old 11-11-2003, 12:21 AM
