Which Cam??
OK, I've been reading the mannnny threads on cams and choices, and have come to the conclusion that my best route is to ask.
I have a '76 2.0L w/ Euro P/C
40IDF Dual Carbs
050 Dist w/ optical and MSD Ignition
Everything else is stock
The car is basically a daily driver, but would like to do some AutoCrossing. Was planning on using the 86a, but wonder if it's too much for a street car.
Help!!!
Old 08-14-2004, 05:35 PM
Member w/ Title Problems
Jason Porter's Avatar
163/86b is a great split duration cam. The 86a isn't too much for a street car IMHO. Then again, I've never met a cam I couldn't drive on the street. Drive with the law not being a prerequisite of course!
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 08-16-2004, 08:52 AM
163/86B requires dual springs and a nice set of heads flowing atleast 70% of the intake out the exhaust... I use a derivative of it in street engines of larger displacement just fine.
For a longer liver with single springs I recommend acam of less than .475 lift.
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 08-16-2004, 09:24 AM
914 Geek
I would think that the 86a and 86b would want more compression than the stock Euro P&Cs would deliver... 8:1 is a bit low for them, yes? They'd probably want at least 9:1 I would think. And in TX, you should be able to get better than the 91-octane crud that we get as "premium" here in CA.
--DD
Old 08-16-2004, 11:53 AM
71 x 94 yields 9.2:1 CR with 0.035" deck and heads cc'ed at 54. That should be sufficient.
Old 08-16-2004, 11:58 AM
Well, we might have more gas in TX, but whether it's any better or not I don't know.
I know that I was having pinging problems before I tore it down, but from reading I think the problem is the dizzy, not the compression.
I plan on cc'ing the heads, but haven't gotten that far yet.
Old 08-16-2004, 12:08 PM
You'll need to figure out your deck height, and cc your heads. Everything you decide on your cam is affected by CR, valve sizes, headwork (springs, porting) exhaust, ignition.
Old 08-16-2004, 12:32 PM
Its all in the combo!
Jake Raby
Old 08-16-2004, 01:25 PM
That's what I hear. I can't wait to tear my engine apart again and make some more changes>
Old 08-16-2004, 01:26 PM
