Which Cam??
OK, I've been reading the mannnny threads on cams and choices, and have come to the conclusion that my best route is to ask.
I have a '76 2.0L w/ Euro P/C 40IDF Dual Carbs 050 Dist w/ optical and MSD Ignition Everything else is stock The car is basically a daily driver, but would like to do some AutoCrossing. Was planning on using the 86a, but wonder if it's too much for a street car. Help!!! |
Member w/ Title Problems
163/86b is a great split duration cam. The 86a isn't too much for a street car IMHO. Then again, I've never met a cam I couldn't drive on the street. Drive with the law not being a prerequisite of course!
Jason Porter - 888-280-7799 ext 233 - jason@pelicanparts.com 1989 Chevy Silverado 3500 - 454TBI, 4x4, 8 gallons/mile |
163/86B requires dual springs and a nice set of heads flowing atleast 70% of the intake out the exhaust... I use a derivative of it in street engines of larger displacement just fine.
For a longer liver with single springs I recommend acam of less than .475 lift.
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com |
Administrator
I would think that the 86a and 86b would want more compression than the stock Euro P&Cs would deliver... 8:1 is a bit low for them, yes? They'd probably want at least 9:1 I would think. And in TX, you should be able to get better than the 91-octane crud that we get as "premium" here in CA.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
71 x 94 yields 9.2:1 CR with 0.035" deck and heads cc'ed at 54. That should be sufficient.
Well, we might have more gas in TX, but whether it's any better or not I don't know.
I know that I was having pinging problems before I tore it down, but from reading I think the problem is the dizzy, not the compression. I plan on cc'ing the heads, but haven't gotten that far yet. |
You'll need to figure out your deck height, and cc your heads. Everything you decide on your cam is affected by CR, valve sizes, headwork (springs, porting) exhaust, ignition.
Its all in the combo!
That's what I hear. I can't wait to tear my engine apart again and make some more changes>
