Ok to Install 1.7 Injectors on a 2.0?
Is it possible to install 1.7 injectors on '73 2.0 engine without problems? What exactly is the difference between the 1.7 and 2.0 injectors?
Thanks,
Old 07-09-2006, 12:23 AM
djpateman's Avatar
flow rate is different, so it will always run lean, and may burn the engine. Not a good idea.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 07-09-2006, 06:17 AM
Can you compensate by adjusting CO mix at the ECU? Other components that one could adjust to compensate?
Old 07-09-2006, 09:00 AM
bowlsby's Avatar
Thats just an idle adjust screw, it has no effct off-idle.
Old 07-09-2006, 11:43 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
No, not enough flow even with all kinds of monkeying with a MPS.
Been there done that!
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 07-09-2006, 10:11 PM
ASE Master Tech - 35 yrs
larrym's Avatar
btdt 2
it will run very lean & HOT & the preignition will kill your pistons
I tried it years ago when I was poor & stupid
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 07-22-2006, 08:11 PM
D-Jet or L-Jet?
I don't think it's a good idea on the D-Jet because I think the D-Jet uses the inducance in the injectors as part of it's firing seqence.
And I just don't think it's a good idea.
Old 07-23-2006, 04:18 PM
Hmm...my mechanic (a very reputable Porsche shop) says it's not a big deal at all. The difference is minimal. Hmmm...
Old 07-23-2006, 04:42 PM
djpateman's Avatar
If you believe that, I can sell you some engines fresh from New Orleans.
Addicted since 1975
Old 07-24-2006, 09:26 AM
Bleyseng's Avatar
as I said, I have tried it and couldn't get enough flow at Wide Open Throttle, not even close! So if Porsche couldn't do it 35 yrs ago when they built the 2.0L in 73 why do you think that it would work now???
2.0L flow way more air with those big ports and big valves so they require way more fuel!
www.914Club.com
My Gallery Page
Old 07-24-2006, 09:40 AM
Just how much is the difference in flow rate. As my boss would say, "Where's the data to support the claim?". ;^)
Old 07-24-2006, 10:49 PM
Bleyseng's Avatar
I don't recall the specs off hand but DD must know!
www.914Club.com
My Gallery Page
Old 07-25-2006, 07:16 AM
914 Geek
Nope, sorry. DD does not know.
However--I do know that it has been tried a number of times over the years, and as far as I know nobody has gotten it to work correctly. I'm thinking the limitation is elsewhere in the system, though, because I recall the injectors themselves have way more than enough flow rate than they need... But at that point, you don't exactly have D-jet anymore.
--DD
Old 07-25-2006, 07:55 AM
djpateman's Avatar
It does not have to be off by much to screw up the air/fuel ratio. Because it flows less, the mixture is lean. Lean mixtures burn hotter and will crack your heads.
The factory could have kept the same injectors and changed the ECU, but elected to keep the same ECU (in 1973) and changed the injectors. This is what highly paid engineers decided to do after much testing, and I am not about to suggest they didn't know what they were doing.
From Brad Anders site:
Flow rate data (courtesy of Roland Kunz):
Yellow (1.7L) - 265 cc/min @ 2.0 Bar, 3V, 0.15 mm ± 0.05 mm lift
Green (2.0L) - 380 cc/min @ 2.0 Bar, 3V, 0.15 mm ± 0.05 mm lift
That is a 43% flow rate increase.
Addicted since 1975
Old 07-25-2006, 08:33 AM
pbanders's Avatar
Send a message via Yahoo to pbanders
Don't do it. The 2.0 injectors are electrically identical to the 1.7 injectors, the only difference is the flow rate. To use 1.7 injectors in a 2.0 motor, you'd need to adjust the MPS to increase the duty cycle of the injectors, across all operating conditions. Getting this "right" has proven to be difficult or impossible for those who have tried before. This may be due to limitations in the drive circuit in the ECU at supporting the higher duty cycle. See my site for additional information.
Old 07-25-2006, 08:43 AM
bowlsby's Avatar
Green 2.0L injectors?
Brad, the early injectors are NLA at the moment, but the later injectors are available. The part numbers are almost identical, ending in 031 and 031A.
Curious to know if you or anyone else has any documented information about the differences between the early (73-74) and late (75-76) 2.0L injectors?
Are the flow rates the same? Are the two part numbers functionally interchangable for all 914 2.0L engines?
Could it be that the respective ECUs or other FI system parts are different enough so that Bosch would have required different injectors or was the updated part just a minor upgrade like for a different/better pintle design or something?
Old 07-25-2006, 10:09 AM
914 Geek
Originally posted by pbanders
This may be due to limitations in the drive circuit in the ECU at supporting the higher duty cycle. ...
That was what I was alluding to in my "elsewhere in the system" comment...
I checked the impedance between two sets I had (8 early injectors, 4 late ones), and the difference was in the noise. When I sent them out for cleaning and flow-rate checking, they appeared to have the same range of flow rates at the beginning, and were definitely the same when they came back.
--DD
Old 07-25-2006, 02:49 PM
pbanders's Avatar
It could be that there was a change made in the later injectors that was related to reliability (e.g. an improved part), and that they are electrically and functionally the same. Regardless, if given the choice between using 1.7 or late 2.0 injectors on a 2.0 displacement engine, I'd use the late 2.0 injectors.
Old 07-26-2006, 04:10 PM
Well, I'm gonna trust you guys over my mechanic. Anyone got a decent pair of 2.0 injectors for sale?
Old 07-26-2006, 11:46 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I have tried it in an attempt to save money in the past. It does not work. You cant play around with the MPS and the FPR all you want, it still runs lean.
Old 07-28-2006, 05:20 PM
