DDS DDS is offline
Post What parts do I need for a bottom end rebuild?
I had hoped to get my car together this year without splitting the cases, but it is not to be. I now have time to rebuild the 2.0. I have completely rebuilt the heads (withe big valves) and have a top-end gasket set and new crank seals.
I might as well do it right and rebuild the bottom end too. I know I need main and rod bearings, what other parts do I need?
Thanks as always.
-- Dave
Pics of my '73 project here: http://members.tripod.com/mike4g/dds73_b4pics.htm
Old 08-15-2001, 11:57 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Porsche Crest
Cam and lifters--practically always. Cam bearings. Inspect the oil pump for wear.
I'm sure there are a zillion other things I'm not thinking of, but the cam and lifters are ones that should be replaced practically any time the case is split.
--DD
Old 08-15-2001, 02:01 PM
roadtrp204's Avatar
Post
Check or have the crank checked. New rod bolts and nuts, which also requires the rods to be trued. Cam, rod, and main bearings of course. Have the oil galley plugs tapped for threaded plugs. Cam and lifters as mentioned, possibly new oil pump. Resurface the flywheel and a complete dynamic balance of all rotating parts. Some assembly required for big smiles next spring.
Chris
75 914 2.0L
Old 08-15-2001, 07:28 PM
Post
Buy one of our complete engine kits, and buy everything at once...These are the same parts we use in the shop, everyday.....All the hard work is done, for you..
Jake raby
www.aircooledtechnology.com
Old 08-15-2001, 08:18 PM
DDS DDS is offline
Post
Thanks - that nails it. I'll search the posts on web cams for D-jet. I still haven't decided if I'll do the big-4 thing or not, this will be subject to hearing the final 'no' on a two sixes I'm chasing.
Jake - you salesman you - I will call to discuss. Thanks again all.
-- Dave
Old 08-16-2001, 05:58 AM
Post
DDS,
I believe a correction is in order here...LOL
Engine builder, not "salesman"....LOL
Old 08-16-2001, 11:32 AM
