Va914's Avatar
3 questions?
I have a '74 which came with a 1.8L L-jet. I now have a 2.0L with a D-jet. Is there anyhing I need to do to the car's wiring harness, relay board..etc to operate the 2.0L? I will be using the d-jet FI harness and the D-jet fuel pump.
Anyone have photo's of the various locations for the D-jet parts? I think I am putting things in the right location but lets see.
ALSO
What Pertronix model number do I need to buy?
Kerry
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 03-06-2002, 04:44 PM
Jim Smolka's Avatar
To install a 2.0 into a 1.8 car is straight fwd. You will need to add a couple of the round relays in the relay board. Also, the MPS must be mounted to the car underneath the battery. The Fuel pump should be the same.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 03-06-2002, 05:18 PM
914 Geek
They're not photos, but you can look to the vacuum hose diagrams elsewhere on this site for the general locations of the pieces.
The only non-obvious ones to me were the MPS and the Decel Valve. The MPS goes on a welded-on bracket on the right-side suspension console. The DV goes on that same bracket, using one of the same mounting bolts.
--DD
Old 03-06-2002, 05:56 PM
Rouser's Avatar
Send a message via ICQ to Rouser Send a message via AIM to Rouser
Click for your Pertronix Ignitor from your friendly neighborhood Pelican Parts.
Rouser!
Old 03-06-2002, 07:34 PM
Va914's Avatar
Thanks guys.
DD those were the two I was really unsure of. Thanks!!
914-6 in the Werks
Old 03-07-2002, 04:48 AM
