3 questions?
I have a '74 which came with a 1.8L L-jet. I now have a 2.0L with a D-jet. Is there anyhing I need to do to the car's wiring harness, relay board..etc to operate the 2.0L? I will be using the d-jet FI harness and the D-jet fuel pump.
Anyone have photo's of the various locations for the D-jet parts? I think I am putting things in the right location but lets see. ALSO What Pertronix model number do I need to buy? Thanks Kerry
Kerry (Back on the road, sort of) 914-6 in the Werks Last edited by Va914; 03-06-2002 at 05:42 PM.. |
To install a 2.0 into a 1.8 car is straight fwd. You will need to add a couple of the round relays in the relay board. Also, the MPS must be mounted to the car underneath the battery. The Fuel pump should be the same.
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
914 Geek
They're not photos, but you can look to the vacuum hose diagrams elsewhere on this site for the general locations of the pieces.
The only non-obvious ones to me were the MPS and the Decel Valve. The MPS goes on a welded-on bracket on the right-side suspension console. The DV goes on that same bracket, using one of the same mounting bolts. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Rouser! |
Thanks guys.
DD those were the two I was really unsure of. Thanks!!
Kerry (Back on the road, sort of) 914-6 in the Werks |
