Limited Slip Differential
Hello,
are the 911 LSD compatibles with 914 gearboxes? In other words, can I mount a 911 LSD in my 2.0 side shift 914?
Thanks!
1967 911 Soft Window targa
1969 911S 2.0 targa
1977 911S Sunroof coupe
1979 911 Turbo 3.3
Old 07-19-2011, 12:04 AM
MarKoBrow's Avatar
Yes
Your welcome
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 07-19-2011, 06:43 AM
901 to 901
915 to 915
I never heard of anyone mixing them.
Old 07-19-2011, 07:18 AM
MarKoBrow's Avatar
Originally Posted by Joe Ricard View Post
901 to 901
915 to 915
The 914 is a 901 trans
2012 Audi A8L
Old 07-19-2011, 07:49 AM
John Rogers's Avatar
If you have a 901 transmission there are three possible ways to add one: first is a factory unit which are guarded by their owners like the gold in Ft Knox, second is a Quaife unit and last is the GT or Guard unit. They all work on different principles, require $$$$$ to install and setup and will most surely change the way the car handles and drives.
Old 07-19-2011, 10:57 AM
gearhead
901 to 901
915 to 915
Not that simple. This should help:
The mag case 911 gearboxes (which includes the 1969 type 901s) use the same differential as the 914. The very early 915 gearboxes also use that same differential.
If one were to acquire a factory ZF LSD for the 911/914 be sure to get the proper LSD stub axles flanges to go with it. The length is greater and the open diff flanges will be too short. Our LSD or TBD does not require LSD flanges. You can use the stock open differential flanges with our units.
Kind Regards,
Matt Monson
Guard Transmission LLC
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-19-2011, 12:41 PM
mike95125's Avatar
Never heard of the different output flange length. Any numbers on the difference in measurements?
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 08-02-2011, 04:03 PM
gearhead
The length to the step on a standard open diff flange is 56mm. The length to the step on the LSD version is 61mm.
1974 914 Bumble Bee
2009 Outback XT
Old 08-03-2011, 04:00 PM
mike95125's Avatar
Thanks for sharing your expertise, Matt.
-74 BMW R90
Old 08-03-2011, 05:11 PM
canna change law physics
red-beard's Avatar
Matt is right. And you need to make sure you keep your own ring gear with the replacement LSD. There are some difference ring/pinion ratio's out there as well. The mid 80's 915 I just had apart had the magnetic speedo parts in it and it did look a bit different from the 1973 unit I have.
James
Red-beard for President, 2020
Old 08-09-2011, 07:35 AM
914 Geek
Considering that the earlier 915s used 7:31 ring and pinion, while the later ones used 8:31, that's not a surprise.
--DD
Old 08-09-2011, 05:00 PM
Arrow Part Number
I know we discused how rare these outdrives are, but do you have a part number for them? Just to see if they might still be available from PORSCHE.
Thanks.
Old 08-24-2011, 06:03 PM
I have a 915 ZF limited slip mounted in my 901 trans in my 914-6. (The 901 ZF limited slips are very to find) It also requires the 915 CVs to be used and adjusted for length to be able to be locked (snapring) onto the 914-6 half shafts. It makes the whole differntial section slightly off-center, but there is enough lateral slop in the CVs to not make this a problem. 30 races later no problems.
Old 08-27-2011, 09:26 PM
Boy, you got that right, found a guy with 2 NOS in the box factory LSD, 1st he seemed like he would let one go (wanted one for my factory "Six" after being hinted a price, I offered, but no, then I even pulled out a few of my RSR bits, still no, then was hinted another price, said OK, but again no
Old 08-30-2011, 06:21 AM
904 lsd
I have a 904 limited slip in a 901 gearbox. I am thinking of selling the diff and replace it with a Quaife. I need to find out if the Quaife acts like a real LSD in that it works in deceleration as well as acceleration. If not I will have to use a Guard Transmission LSD in my 914 race car.
914racer
Old 03-04-2012, 05:39 AM
jhora's Avatar
Matt and mike...Tony at Stuggart Specialist here in KY had some pictures of the two types of flanges side by side...I think they were here on pelican...or he may still have them...
John
Old 03-04-2012, 09:31 AM
Max Sluiter
Flieger's Avatar
Quaife is most known for torque-biasing differentials (TBDs), aka Torsen differentials. These use worm gearing to bias torque to the wheel that is turning faster as long as the slower turning wheel (the inside wheel) does not loose traction completely. The traction on the inside wheel is effectively multiplied by the worm gearing into a torque bias towards the outside wheel. If traction gets too low then the inside wheel spins and all the benefits are lost. It works on acceleration and I don't see why it should not work on deceleration but people say they do not. It may be that the torque bias is not a stabilizing one and so it does work, but not in the manner desired.
An "LSD" is usually referring to a plate clutch type limited slip differential which simply tries to maintain equal wheel speeds across the axle using static friction and preload and then kinetic friction when things start slipping. This works the same on power and off power. It is a stabilizing (understeering) influence in both regimes.
Some differentials for Formula SAE combine both the torque biasing and clutch plate types into one unit.
Some race cars use a spool, just a straight piece of metal making sure that both wheels spin the same speed (except for torsional windup). This introduces a lot of understeer unless you make the rear end very stiff like a kart, in which case if you are cornering at high g and unload the inside wheel, while still driving the outside wheel, you get a torque vectoring effect, helping to turn the car.
Old 03-04-2012, 10:58 AM
