Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Harpo's Avatar
For those of you using headers
For those of you using headers what did you do with, or how did you modify your stock cooling system?
Old 05-13-2012, 02:51 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Scrappy's Avatar
You don't modify much of anything.
The cooling flaps on the impeller housing remain open. Plugging them is supposed to interrupt / change the air flow characteristics in the impeller housing.
Next you cap the heater inlet tubes in the engine compartment ... the ones that go into the body. This way you don't get engine compartment fumes in the cabin.
Ron Meier
Backyard Shadetree Mechanic
1974 914/6 conversion with 2.7L (The Grey Ghost)
1973 Chalon with 2.4T MFI (Schlitzalom)
All my 4 cylinders are gone
Old 05-13-2012, 07:26 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Harpo's Avatar
What about that air that is being directed down to the heat exchangers? Should that be rerouted across the cylinders?
Old 05-14-2012, 03:42 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
r_towle's Avatar
The electric engine bay fan gets deleted, both 2.5 inch holes in the tin get covered up and sealed to ensure the heat stays below the engine bay.
Both tubes into the body get capped off (spray can covers fit perfectly)
The little flapper doors on the bottom of the main fan housing typically get left open.
Rich
Old 05-14-2012, 03:48 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Non User
infraredcalvin's Avatar
I plugged the above mentioned holes and kept the t-stat hooked up, never had a problem with cooling (street car mainly), the t-stat helped bring oil up to temp quicker, and opened just fine when up to op temp.
Infraredcalvin - AKA Pat
'76 Turbo Carrera - Factory LSD, 1 bar spring, Kokeln Turbocharger, Rarlyl8 muffler, '83 930 brakes
'75 914-4 GT track project
'12 Jeep Grand Cherokee SRT8
Old 05-14-2012, 09:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
