DSPTurtle's Avatar
Trailing Arm Help
I need some help!!! Before I figured out the easy way to remove the shaft in the trailing arm I was using a BFH. Well, I destryoed some threads. Does anyone have an extra one of these shafts they would be willing to part with?? Or... (the reason I am posting here) does anyone know if it would be safe to grind off about 1/4 to 1/2 inch and still get enough thread engagement?
I am ready to go five bolt but this is now holding me up!!! Please help!
JB
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 05-15-2002, 07:49 PM
Zeke's Avatar
Here's an old shadetree mechanic trick, rather crude, but it might work. Get a nut for the shaft. Cut it in half. I have also cut across the threads in the open half to make a crude die. Place halves on good threads with oil and clamp down with vise grips easy enough so that nut will turn. Back off over damaged threads. IF you can figure out how to cut a grade 8 nut, it'll probably straighten out the threads
Old 05-15-2002, 08:30 PM
canna change law physics
red-beard's Avatar
Why not go to Home depot and buy a thread die and "chase" the threads? A tap and die set is usually the cheapest way to go, but you'll have to buy the specific metric die for you're application.
James
James
Red-beard for President, 2020
Old 05-15-2002, 08:45 PM
DSPTurtle's Avatar
Guys,
I already did the grinding. There was no way a die was going to fix it!!! Now it works again but it is about a 1/4 inch shorter than it should be!!!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 05-16-2002, 05:44 AM
gregk1's Avatar
Are you talking about the part that goes thru the spindell that has the splines on it. If you are I think I have an extra one.I think it is good I will have to look and let you know tomarrow. If you want it let me know Greg
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 05-16-2002, 09:51 AM
914 Geek
I agree with Brad from All914's suggestion on the Yahoo 914 OA mailing list. Replace the stub axle. Sounds like you may have found a source in gregk1!
--DD
Old 05-16-2002, 01:52 PM
DSPTurtle's Avatar
Greg,
It sounds like you are talking about the hub... this is actually the part that goes through the trailing arm to mount it to the frame. It is about a 2 inch wide shaft that is about 1 1/2 ft long. It has two threaded ends for bolts. Let me know if this is the part you have cause I really need to get ahold of one!!!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 05-16-2002, 08:03 PM
gregk1's Avatar
Damm I had a bent trailing arm. It layed around for ever and I thru it in the scrap. SORRY I know that part of was good to. I dont throw P parts away but I looked at that and said what am I going to use off that. I wished I could have helped you. Oh well better luck next time Greg
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 05-17-2002, 06:07 AM
Zeke's Avatar
James
James, when the end is damaged by hammering as turtle indicated, there's little chance of starting a die straight w/o cross-threading. You need to get the die out in the middle of the good thread and work outward. I'm sure there are two-piece dies that do that, but for a one time /one chance save, my method will sometimes work.
Old 05-17-2002, 02:44 PM
DSPTurtle's Avatar
Dudes!!! Check it out. Only one side is done cause I still have not found another shaft. But it looks oh so pretty with those five studs!!!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 05-20-2002, 07:15 PM
JB,
Nice looking work! Are you using early (with the raised pads for 5 lugs) or late model rear hubs? Who drilled your hubs?
Thanks,
Mike
Old 05-22-2002, 06:18 AM
DSPTurtle's Avatar
I did it!!!
Check it out!!!
All I need now is a 911 front end!!! The new 205.50.15 Bridgestones are awesome!!! I love the look of the Cookies!!! Maybe cause my first Pcar was a 944...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 05-27-2002, 06:55 PM
Didja torque them rotors down to 90 ft/lbs to set your venting clearance? Sure you did
JPIII
Early Boxster
Old 05-27-2002, 07:30 PM
DSPTurtle's Avatar
Those are "front" calipers. The rears are in a box somewhere. Those will be replaced with the 320i brakes I have on the front right now as soon as I find a 911 front end. That venting clearance stuff was no fun
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 05-28-2002, 08:41 AM
