3D914's Avatar
Electrical problems too! Please help
Here is the situation: I was getting ready to pull out of my parking spot at work when alternator light came on, then all my guages died (alternator, tach, fuel, oil pres, oil temp, and volt) and my turn signals, brake lights and reverse lights dont work. I can start the car and it runs fine. I drove it home about 16 miles. No noticable drain on the battery. Also checked the voltage output from the alternator and its 12.5v.
There are no blown fuses.
The stereo, powered from #9 fuse works fine also.
I've checked/cleaned the ground next to the fuse panel, swapped out the Volt-Reg with a working one, checked the grounds at the rear, and also the reverse light connector on tranny. All checkout OK.
The only noticable change recently is that my left turn signal switch doesn't return when the wheel comes around to straight, I have to manually return the switch to the off position.
Does anyone have any ideas!!!!!?????
TIA,
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 08-15-2002, 10:07 PM
One thing I’d check is the secondary power connections on the positive side of the battery, I think I have 4 in addition to the beefy cable going to the starter. It’s possible one or more of those connections may be bad. The fact that you can start and run the car indicates clearly they are not all bad.
I would guess the left turn signal problem is just an unfortunate coincidence.
Tim
timw700@hotmail.com
Old 08-16-2002, 06:33 AM
914 Geek
Check fuse #8 as well as #9. I forget which of those powers the circuits mentioned, but one of them does. Check very carefully--the fuse can look OK on first inspection but still be blown.
--DD
Old 08-16-2002, 09:01 AM
3D914's Avatar
Dave,
Good call! You get the 914 Yoda of the week award!!
I went out to the parking lot, pulled the #9 (4th from right) fuse again, and the little metal cone at the bottom broke off from the fuse strip. This explains why the gauges would occasionally come up while driving.
It doesn't apear to be a blown fuse, as it appears to be a clean break where the strip bends to form the cone at the bottom. I just happened to have a loose spare in the golve box. Time to buy some more 16amp fuses.
Thanks again,
Gerard
Old 08-16-2002, 11:53 AM
