Guest
Posts: n/a
Question on Setting Ignition Timing
1973 914 1.7,ignition timing adjustment procedure
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Check here for what you need:
I would grab a repair manual. It will have the procedure, special tools and torque specs. Give our parts specialists a call at 1-888-280-7799. - Nick |
914 Geek
I think the link was left out of your post, Nick.
Pelican Technical Article: 914 Timing and Dwell Adjustment Note that the specifics are for the stock fuel-injected motor. If you have a non-stock motor (including a carb conversion) the specs could be different. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
