Question e-brake using 930 calipers
is it possible to retain the parking brake with 930 rear calipers? does it require any modification?
brian
Old 12-06-2002, 09:43 AM
mike mueller's Avatar
A few different ways to do this:
Line-lock, which some say work, some say they don't, I've never used one.
or
Convert the rear trialing arms to accept the 911 parking brake which is actually a drum brake mounted "inside" the rotor.
Vellios or Rich Johnson I think offer these kits...not cheap
or
make a bracket and mount a Wilwood Mechanical Spot Caliper
(about 70 bucks each for the calipers)
Clay Perrine (sp?) is or was selling a kit for this or maybe just the brackets.
'73 914, 1.7, with Boxster transmission in the future?
Old 12-06-2002, 10:34 AM
yup
THE 911 e-brake didnt change from ~70-89 and they are all compatible.
check the third page
911 brakes for my 914/6
Kelly
Old 12-06-2002, 10:36 AM
this thread is also very helpful
Brakes
BTW
I have an extra 911 ebrake setup if interested
Kelly
Old 12-06-2002, 10:41 AM
Kelly,
for the mechanically challenged, your answer would make it sound like it's a bolt on procedure, which it is not
also, Brian is a little vague with his question, does he want to know if he can keep his stock 914 parking brakes with the 930 calipers?
If so, the answer is a no for sure. Okay, that's a lie, he could
use the factory 914 parking brake with the 930 caliper if he mounted the 930 caliper on the trailing edge of the rotor, but that seems like even more work to do that.
Great links, I have never seen the 911 parking brake setup even after owning a 911 for a while now (no need to take it apart...yet, LOL)
Old 12-06-2002, 10:52 AM
thanks for the insight that helps alot.
brian
Old 12-06-2002, 11:17 AM
Brad Roberts's Avatar
Mueller,
Perrine's setup is for a 22mm 911 SC rotor..not a 24mm Carrera or a mondo Turbo rotor.
B
Old 12-06-2002, 12:00 PM
how do i get a hold of Perrine? i have boxster calipers set up on my six with 911 rear rotors, so would appreciate a simple solution
Thanks!
Old 12-16-2002, 05:34 PM
914 Geek
Look around http://www.perrinefamily.org . I'm sure there's an email link somewhere there.
--DD
Old 12-17-2002, 09:19 AM
thanks- i've sent him a message
Old 12-17-2002, 09:49 AM
